Home » Archived » BIRT » Is it possible to make page witdth larger then it is by default
Is it possible to make page witdth larger then it is by default [message #93318] Mon, 21 November 2005 06:42 Go to next message
Originally posted by: mra.netcetera.com.mk
I am using birt 1.0.1. The page has default width and I couldn't find
the way to make it with larger width.
Thanx for suggestions.
Re: Is it possible to make page witdth larger then it is by default [message #93333 is a reply to message #93318] Mon, 21 November 2005 07:37 Go to previous messageGo to next message
Originally posted by: mlorenz.nc.rr.com
If you go to the Outline window for the report, you can expand the
MasterPages item. Then select your Simple Master Page (or whatever type
is shown). Now, select the Property Editor window and select Margins.
HTH, Mark
Re: Is it possible to make page witdth larger then it is by default [message #93380 is a reply to message #93333] Mon, 21 November 2005 08:55 Go to previous message
> HTH, Mark
Thanx for advice, it helped :)
Previous Topic:Text padding and margins problem
Next Topic:How do you close the output report file?
Current Time: Tue Jul 22 14:00:44 EDT 2025
Powered by FUDForum. Page generated in 0.03722 seconds
