1.1RC3: images in ToolBar [message #93210] |
Fri, 13 June 2008 04:06  |
--------------000703080807060903090108
Hi all,
when I've a ToolBar with images only tool items and drop down buttons,
the last drop down button gets out of the Shell.
Probably there's something wrong in tool item bounds calculation?
In the attached code snippet the image is 16x16, and the last drop down
button isn't visible.
Enrico
Content-Type: application/octet-stream;
name="src.zip"
filename="src.zip"
UEsDBBQAAAAIAINuezYltIMGOAEAAD0BAAAIAAAAaWNvbi5naWaNj98vAgEc wL9tRrPQFKWk
3cRuOsNZQ83EKWk55ceQYWG0edDirXpojSxLMlM3O9ftVgujrT8B06x5Mf4A m/kDvHk67j/o
8/Z5+3wmJq2DQx4pSOEDBHiez6Fd2hAgIdAGYJ2z6iMi03HDKmP0Zq2GaA2R aGJLMUtCsX87
7UohC2k0Xz4NFuZvysm713MP3bPB9G2z/TvcwG522N8NPgz29BBoh0fqqESf lOjES+Ys3AJR
OeRG8LgE4nXAdmryRvzeThRnp1JiUVoipuUyRtGcUas4BPlPgspAfqtEADhg gghPUO02Uz4b
popT3E+jq96gLH999j4fUrWWNycWK1xIH8w6SYSFb/e144kIK2UHZubda0OL pA7tUC+Sba3j
DrtmzDkzR+JLyytr9s0tb5LwXwavyFEw/QFQSwMEFAAAAAgAhZjMOBd7OgI0 AwAACgsAAAwA
AABSYXBUZXN0LmphdmGdVl9v2jAQf5/U7+DyZDYUUfpHkyqk0RZaJEpQyFZp L1WID7DkxFHs
QNHW7z47DkkgpCv4wbHPv7vfne07hwYRjyXi8cICn9FIgBWvpbWIvWhJfWE9 ZoPbsy81UEbn
4G98BtawH8p4M+E0lIfhQsGnL279op8IyQPraz0CVhBKUYsoXP8Qw7wNT6Q1 oIyN0mE9dE3J
AjLGsy9RMmPURz7zhECOF7kgJFKaDALtFyptAfqjFZBqP+wVxDElYKaZDQ3x Y/Ak/Bzipkaj
rM1p6DH0QEWk/EQEdVEI6+0cN28L5HQJjCFxYSBmikkLqU22pk/90ejVdYbP JQ2FtQRIF94k
bky8WDlttBpV0B1PQiLwRbvdQmn3XXc37fYBD3YcEBcfelA4cL+kjBziL9F3 NGmnTF9BmiPE
2oHiRHGzjCtG9643G3BGIEZynrldyLAwrrv2xKgXSkMJAZI02+tchOXcqIzt cb+ko6FFpHYI
jRqDnc8b7BQG3TXfMbh/e1zO2Z2nY5QzQ7AV5fafbGf42x67vRH6mwoGo567 QzhP+Xjk0MVS
Ym3qMOUw8BaAqM9DRfW4zT+VNukCbugVa0HnjRZSwnudPLip1x0QPIl96Imp VKkQlKDN/0Vn
tm+en0guTB01IT449uT1wX4Z74aVHs3WO82olj9i6JzA0DmK4fIEhsujGK5O YLg6iuH6BIbr
oxhuTmC4qWfYvxIeIVNg4EvKwxEVEkJVEDRfLu0RL5JKuFOu90v8thWlfsUp QeYhMaaA4Nxm
f6WLMBiTe43OMQKLgPQoQ91uGmnPcewXlMGr7RnCBAVmo9JJlrf16HR7g20a 5SIc7JehagvK
NW5AYyEbn2DqnMRUKn5TUCdJaqkOSx213V64YIBiNULd7NAX+UtTZ8685pE0 Xpsp1jastxZK
vxv0zQyWoCtlnaFoh9W8vqoOSr592iN5XEhB+vpx39P3SGlrh1S/UVbq8b+o oDMGWMYJHAK+
Z6Lq9P1w8ojsdwrv/ULwCMJdWVW0XlLlCjpXcCr0NnChcqNprvd+JpwTSz0S pBcSjfSkv9TI
agTEEgwgMkTVMGKQSRyidrb6rn/TVPcPUEsBAhQAFAAAAAgAg257NiW0gwY4 AQAAPQEAAAgA
AAAAAAAAAAAgAAAAAAAAAGljb24uZ2lmUEsBAhQAFAAAAAgAhZjMOBd7OgI0 AwAACgsAAAwA
AAAAAAAAAAAgAAAAXgEAAFJhcFRlc3QuamF2YVBLBQYAAAAAAgACAHAAAAC8 BAAAAAA=
--------------000703080807060903090108--
Re: 1.1RC3: images in ToolBar [message #93269 is a reply to message #93225] |
Fri, 13 June 2008 05:59  |
Yes it is, thanks Ivan!
I've added a comment to the bug and a simple workaround.
I report here the comment:
truncation happens if the tool bar has image-only items. If adding text
with setText, buttons are not truncated.
I find a workaround: subclassing ToolItem and override getWidth to
return (super.getWidth() + 2).
It seems to work for images only tool bar.
Code snippet here:
class MyToolBar {
....constructors here...
protected void checkSubclass() {}
public int getWidth() {
return (super.getWidth() + 2);
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> maybe your problem is the same as reported in bug 233139.
> Best,
> Ivan
> Enrico Zanaga wrote:
>> Hi all,
>> down button isn't visible.
>> Thanks,
>> Enrico
FUDForum. Page generated in 0.14301 seconds
