Home » Archived » Hudson » JDK Insatllation
JDK Insatllation [message #932667] Thu, 04 October 2012 06:03 Go to next message
Hi everybody,
this is my first article and i hope you can help me.
I am new on Hudson so i tried to configure the JDK installation, but i always get the message "JDK automatic installer temporarily disabled, please install JDK manually and specify valid JAVA_HOME".
So what can i do or how can i enable the installer??
Re: JDK Insatllation [message #932675 is a reply to message #932667] Thu, 04 October 2012 06:14 Go to previous message
Hello Sebastian and welcome!
One alternative solution is if you uncheck the Install automatically, you can manually set the JAVA_HOME. If you are linux, you can go to a terminal and type "echo $JAVA_HOME" or in windows and type "echo %JAVA_HOME%" and set the variable in hudson based on the output.
Previous Topic:Build on a specific date and time
Next Topic:man page for plugin classes
Current Time: Sat Jul 26 20:58:35 EDT 2025
Powered by FUDForum. Page generated in 0.03956 seconds
