Home » Eclipse Projects » Eclipse Scout » Wizard test
Wizard test [message #921068] Sun, 23 September 2012 15:55 Go to next message
I tried to use the wizard and have some problems with it:
If I start the wizard it comes up at full screen size. I like to have it smaller but don't see how. Then the previous and next buttons are at the bottom of the screen. When I use the next or previous button, the screen gets even bigger, so the next and previous button move off the screen so I can't use them anymore.
Any hint how I should use it.
Re: Wizard test [message #921521 is a reply to message #921068] Mon, 24 September 2012 03:27 Go to previous messageGo to next message
Hi Bertin,
This sounds like a layouting problem to me. Please check the gridH and gridW properties of the fields on your wizard forms to make sure the fields are not too big. Does the same thing happen if you just open the form without the wizard?
Btw: When using wizards as dialogs I suggest setting a fixed height and width so that the dialog does not change it's size when stepping next and back. This needs to be done on the mainbox of the wizard container form, see also IWizard#execCreateContainerForm().
Hope it helps
Claudio
Re: Wizard test [message #923052 is a reply to message #921521] Tue, 25 September 2012 11:09 Go to previous messageGo to next message
Hi Claudio,
The forms contain just one field. If I open them seperately they are very small.
I can get the mainBox, inside the method execCreateContainerForm but have no idea how to set a fixed height and width then. Do you have a code example.
Regards Bertin
Re: Wizard test [message #929438 is a reply to message #923052] Mon, 01 October 2012 09:09 Go to previous messageGo to next message
Hi Bertin,
The reason why the wizard is so big can be found in the DefaultWizardContainerForm:
protected int getConfiguredGridH() {
  return 32;
Do you have a small screen resolution? The wizard probably is too big for your screen. It seems that the size gets automatically corrected when the dialog opens so that it fits to the screen. But when changing the step, a relayouting is done which does not consider the screen size anymore. But this is just a guess, I haven't analyzed it further.
You may now change the gridH to a smaller value or directly set width and height in pixel, as already mentioned. To do that you can either use the DefaultWizardContainerForm as template, copy it to your project and change what you need. Or you can do it directly in the wizard:
protected IWizardContainerForm execCreateContainerForm() throws ProcessingException {
  IWizardContainerForm f = super.execCreateContainerForm();
  GridData gd = f.getRootGroupBox().getGridData();
  gd.widthInPixel = 400;
  gd.heightInPixel = 400;
  f.getRootGroupBox().setGridDataInternal(gd);
  return f;
Hope it helps.
Claudio
Re: Wizard test [message #929529 is a reply to message #929438] Mon, 01 October 2012 10:42 Go to previous messageGo to next message
Claudio Guglielmo wrote on Mon, 01 October 2012 15:09
I experienced something a similar in my Scout Application (Swing - Scout Version from Jan-2012).
The bug with a minimal example can be found here: Bug 372222
Have also a look of the code Snippet proposed by Ken Lee. It ensures that the screen bounds are considered when a Form is resized.
[Updated on: Thu, 04 October 2012 07:08] by Moderator
Re: Wizard test [message #932666 is a reply to message #929529] Thu, 04 October 2012 06:01 Go to previous message
Thanks it helps,
setting the gridData keeps the container small.
regards Bertin
Previous Topic:DataSourceSecurityFilter ClassNotFoundException
Next Topic:Adding rows to tablefield
Current Time: Sat Jul 26 03:33:01 EDT 2025
Powered by FUDForum. Page generated in 0.05870 seconds
