Home » Modeling » M2T (model-to-text transformation) » [Acceleo]Using 2 metamodels in combination with 2 separate model instances
[Acceleo]Using 2 metamodels in combination with 2 separate model instances [message #932663] Thu, 04 October 2012 05:59 Go to next message
Context:
MM 1: ER metamodel
MM 2: Policy metamodel wich refers to metamodel1 and uses metaconcepts that are defined in MM1
Model1 (model1.er): instantiation of MM 1 which is created using an EMF generated editor
Model 2 (model2.policy): instantiation of MM2 which contains a reference to Model 1 and uses concepts defined in model 1
Problem:
I can define an mtl generation file using Acceleo which contains no syntax errors. However when I run this file there seems to be something wrong when I want to use the references in model2 to elements in model1. Seems like model2 cannot find model1.
Thanks in advance,
Frederik
[Updated on: Thu, 04 October 2012 09:16] by Moderator
Re: [Acceleo]Using 2 metamodels in combination with 2 separate model instances [message #938860 is a reply to message #932663] Wed, 10 October 2012 04:13 Go to previous message
It seems odd, well you can force the loading of all the related resources by using the commented line (//org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(model)) in the method "doGenerate" of your java launcher. You can look in the resource set of your model to check that both models are properly loaded (model.eResource().getResourceSet().getResources()).
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:MWE2 and xpand outside eclipse
Next Topic:[Acceleo] Ordered unbound choices / EFeatureMapEntry
Current Time: Fri Jul 25 11:10:49 EDT 2025
Powered by FUDForum. Page generated in 0.12209 seconds
