Home » Modeling » QVT-OML » use of libraries
use of libraries [message #930706] Tue, 02 October 2012 11:02 Go to next message
I'm trying to modularize my transformation code into sorted libraries.
Separating helpers and queries works but i can't separate a call to a mapping and its definition. When i do it, it tells me that it cannot find operation.
Is there a way to tell to the interpretor that it has to look into the library?
thanks,
Cuauhtemoc.
Re: use of libraries [message #930733 is a reply to message #930706] Tue, 02 October 2012 11:31 Go to previous messageGo to next message
The OMG specification on the packaging of transformations is vague and I
have no idea what QVTo does.
You could try referencing as MyLibrary::MyTransformation
Ed Willink
On 02/10/2012 17:02, castellanoscuauhtemoc@xxxxxxxx cuauhtemoc wrote:
> Hello,
> find operation.
> library?
> thanks,
> Cuauhtemoc.
Re: use of libraries [message #930804 is a reply to message #930733] Tue, 02 October 2012 12:56 Go to previous messageGo to next message
Hi Cuauhtemoc;
For me, a simple "import" works fine. Here it is a small example based on the SimpleUML to RDB example (there are two packages, p1 and p2):
import p2.Map;
modeltype UML uses 'http://www.eclipse.org/qvt/1.0.0/Operational/examples/simpleuml';
modeltype RDB uses 'http://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb';
transformation Simpleuml_To_Rdb(in uml : UML, out RDB);
main() {
	uml.rootObjects()[UML::Model]->map model2RDBModel();
mapping UML::Model::model2RDBModel() : RDB::Model {
	name := self.name;
	schemas := self.ownedElements[UML::Package]->asOrderedSet()->map package2schema();
library Map;
mapping UML::Package::package2schema() : RDB::Schema
	name := self.name;
Regards;
Re: use of libraries [message #931756 is a reply to message #930804] Wed, 03 October 2012 09:45 Go to previous messageGo to next message
it works very well thank you!!
The error it was that i was trying to import transformation mapping, not librarry.
Do you know how to have an superimposition behaviour?
I know that it is not included in the standard but this feature is powerfull for maintainablity and evolability of transformation.
Otherwise i would make wrappers.
Thanks;
Re: use of libraries [message #931795 is a reply to message #931756] Wed, 03 October 2012 10:31 Go to previous messageGo to next message
Sorry, I have no clue... I'm not familiar with the concept of superimposition. If you describe a concrete example, maybe someone can help.
Regards;
Re: use of libraries [message #932595 is a reply to message #931795] Thu, 04 October 2012 04:53 Go to previous messageGo to next message
In fact, I'm trying to give to my transformation a wrapper pattern structure, that ease adding functionnalities to my transformation.
There are disjuncts mappings that decide which functionnality to use. The point is that each library has to be able to call the wrapper, but the wrapper import them and the wrapped functionnalities has to import the wrapper to call it. So I have some cyclic dependencies.
Superimposition allow to implement this kind of structure. I'm wondering if there is a way to implement it in separated libraries.
Re: use of libraries [message #932601 is a reply to message #932595] Thu, 04 October 2012 04:57 Go to previous messageGo to next message
Cyclic dependencies are often challenging if not actually ill-formed.
Naively it would seem to me that you have a modularization problem if
your wrappers are not almost dependency-free.
Ed Willink
Re: use of libraries [message #932780 is a reply to message #932601] Thu, 04 October 2012 08:23 Go to previous messageGo to next message
Simply, I have a library A (the wrapper) which import library B (the wrapped), but library B needs to call the wrapper.
I didn't understand what a module realy is, and how to use it. "Its a unit containing a set of operations and types defined to operate on models", but is it a transformation, a library? It is not very clear to me.
If you can enlight on this point.
Cuauhtemoc
Re: use of libraries [message #932912 is a reply to message #932780] Thu, 04 October 2012 11:06 Go to previous message
Hi Cuauhtemoc;
Maybe I did not understand your question, but in the QVT specification a library and a transformation are modules (specializations of the "module" metaclass) (see page 78). I don't know why the "module" metaclass is not abstract, i.e., what is a module that is neither a library nor a transformation...
Regarding your problem, try to reorganize your libraries in order to avoid Library B calling Library A ("wrapped" calling the "wrapper"). As Ed commented, cyclic dependencies are often an indication of an inadequate organization (not cohesive enough). Ask yourself if it is really necessary. If it *really* is, a simple solution is to move the A's mappings & queries used by B to another Library (C, for example) and make A and B import it.
Regards;
Previous Topic:Save Traces to a file during a standalone transformation run
Next Topic:[Announce] Eclipse QVT Operational 3.2.1 (Juno SR1) is now available
Current Time: Wed Jul 23 07:46:58 EDT 2025
Powered by FUDForum. Page generated in 0.05834 seconds
