Concrete syntax vs desired model structure [message #931719] |
Wed, 03 October 2012 09:10  |
Suppose I have a language with function declarations like the following
f(x : int; y : bool)
g(x, y : int; z : bool; w : int)
h(x, y, z : bool; w : bool)
The point is, the parameters to a function may be grouped if they have the same type. I can use the following grammar to parse this:
FunDecl:
name=ID '(' args+=VarGroup (';' args+=VarGroup)* ')' ';'
VarGroup:
(vars+=Var (',' vars+=Var)*) ':' type=Type
Var: name=ID;
Type: 'int' | 'bool';
The downside is that the resulting model is somewhat annoying to work with since from a function declaration I can't immediately get a list of all its parameters. Instead I get a list of VarGroups and I have to extract the variables from each of those. Another pain is that given a variable, I need to navigate the model a bit in order to get its type. I would much prefer a model where a FunDecl has a list of variables, each of which has a type associated with it. Is there any way of structuring my grammar to achieve this (without modifying the concrete syntax)? I don't know if it's worth the trouble of using a custom Ecore model, but would that even solve this problem?
Andrew
Re: Concrete syntax vs desired model structure [message #931924 is a reply to message #931719] |
Wed, 03 October 2012 12:55   |
Andrew,
This is a general problem with DSLs: The envisioned concrete syntax is
often not close enough to the most convenient abstract syntax.
Sometimes you can bridge the gap by defining derived features, that
compute abstract syntax features from concrete syntax features. E.g. the
parameters feature of the Function class is derived from the varGroup
feature. So the parser fills the varGroup list and the derived feature's
getParameter method computes what's most convenient for the user of the
model.
There usually is a time trade-off that may be handled by caching lists
computed for derived features. If you set volatile to false, you get an
list field into which you can store the computed list.
Hallvard
> FunDecl:
> VarGroup:
> Var: name=ID;
> Andrew
Re: Concrete syntax vs desired model structure [message #932145 is a reply to message #931719] |
Wed, 03 October 2012 17:52  |
You can introduce a derived feature through extension methods in Xtend.
class FunDeclExtensions {
def static Iterable<Var> getVars(FunDecl it) {
args.map[vars].flatten
then you can use it like in this snippet ...
import static extension mypackage.FunDeclExtensions.*
def someCodeGeneration(FundDecl funDecl) '''
<<FOR var : funDecl.vars>>
<<ENDFOR>>
Am 10/3/12 3:10 PM, schrieb Andrew Gacek:
> FunDecl:
> VarGroup:
> Var: name=ID;
> Andrew
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
FUDForum. Page generated in 0.52836 seconds
