Home » Language IDEs » Java Development Tools (JDT) » prevent automatic import-statements
prevent automatic import-statements [message #93128] Mon, 08 September 2003 08:53 Go to next message
Hello, when I type a unused type in the editor, the codegenerator adds the
required import-statemant automatically. But I don`t want that. I want to
control what and when I import by myself. I think in a previous version of
eclipse a lightbulb with a red sign appeared and when I clicked on it, it
suggest me to import. Thats the way I would prefer it to work. Can I
change it somehow ?
Re: prevent automatic import-statements [message #93143 is a reply to message #93128] Mon, 08 September 2003 08:59 Go to previous messageGo to next message
Window->Preferences->Java->Editor->Code Assist->Insert single proposals
automatically
Jerome
"Robert Ludwig" <SCHWERTFISCHTROMBOSE@GMX.DE> wrote in message
news:bjhu4q$9j3$1@eclipse.org...
> change it somehow ?
Re: prevent automatic import-statements [message #93156 is a reply to message #93143] Mon, 08 September 2003 09:01 Go to previous messageGo to next message
Sorry I meant: Window->Preferences->Java->Editor->Code Assist->Automatically
add import instead of qualified name
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bjhud8$a04$1@eclipse.org...
> automatically
> Jerome
the
to
of
it
> > change it somehow ?
Re: prevent automatic import-statements [message #93186 is a reply to message #93156] Mon, 08 September 2003 09:05 Go to previous messageGo to next message
err, no, when I uncheck that one, eclipse adds the complete qualified name
instead of the import statement. But I onkly want to prevent the AUTOMATIC
import-statment-gneration. I want to be asked before, wether I want to
import or not. Like it was with that light-bulb thingy.
Re: prevent automatic import-statements [message #93230 is a reply to message #93186] Mon, 08 September 2003 10:51 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
The 2.1.1 version of Eclipse does not add the import automatically. It adds
when you use the content assist to get a completion for a class name. If you
write the whole class name without using completion the "light-bulb thingy"
appears and add a quick-fix possibility to import the class.
Personally: I think the completion *must* import (or use the full name)
because without that a compiler error occurs in the code (and because I like
the 'compile on save' functionality it would really hurt and slow me down).
Also you cannot get any content assist information for that class (and
variables of that type) until you import it manually.
HTH,
Csaba
news:bjhuq2$ahc$1@eclipse.org...
Re: prevent automatic import-statements [message #93441 is a reply to message #93230] Tue, 09 September 2003 04:32 Go to previous messageGo to next message
Is there any way to, like in IDEA, press eg ALT+ENTER to import the
package instead of getting your mouse, pointing it at the ligh bulb,
clicking, selecting...
thanks
Ronald
Horváth, Csaba wrote:
> HTH,
> Regards,
> Csaba
Re: prevent automatic import-statements [message #93471 is a reply to message #93441] Tue, 09 September 2003 05:50 Go to previous messageGo to next message
You can do any of the following with keyboard shortcuts:
1. Use content assist (ctrl+space) when type the class name (or right after
it): this will add the necessary import
2. Use quick-fix (ctrl+1) when the cursor is in the type you want to create
the import to: it will show you the same possibilities as clicking on the
light bulb
3. You can use 'Organize Imports' to synchronize all import statements to
the code (ctrl+shift+o)
HTH,
Csaba
"Ronald Vanschoren" <ronald.vanschoren@wol.be> wrote in message
news:bjk364$dev$1@eclipse.org...
> thanks
> Ronald
> Horv
Re: prevent automatic import-statements [message #94238 is a reply to message #93128] Thu, 11 September 2003 03:58 Go to previous message
Originally posted by: daniel.megert.gmx.net
Robert,.
following your other message you neither want an import nor full
qualification. Can you describe the use case for such a behavior?
Dani
>change it somehow ?
Following your other comments you neither want an import nor full
Dani
Previous Topic:Package Explorer View Drop Action
Next Topic:hierarchy linked to correct editor?
Current Time: Tue Jul 22 03:27:23 EDT 2025
Powered by FUDForum. Page generated in 0.06795 seconds
