Home » Eclipse Projects » Remote Application Platform (RAP) » Set Custom Variant for TableColumn not working.(want to hide sort indicator for unsortable columns by setting custom variant)
Set Custom Variant for TableColumn not working. [message #931047] Tue, 02 October 2012 18:06 Go to next message
I have a stylesheet with the following variants:
TableColumn-SortIndicator, TreeColumn-SortIndicator {
  background-image: url( icons/sort_indicator.png );
TableColumn-SortIndicator.nonSortableColumn, TreeColumn-SortIndicator.nonSortableColumn {
  background-image: none;
I have all columns showing a sort indicator with an up/down arrow shaded gray. Some columns are not sortable, and I would like to hide the sort indicator. So the styling in the css file above works to show the sort indicator. And on the column that is not sortable, I set the custom variant as follows:
  TableViewerColumn col = new TableViewerColumn(this,SWT.NONE, columnIndex);
  col.getColumn().setData(WidgetUtil.CUSTOM_VARIANT, "nosSortableColumn");
The column still shows the sort indicator. I am setting other custom variants this way, and the styling is respected, is there a reason this is not the case here?
Re: Set Custom Variant for TableColumn not working. [message #931511 is a reply to message #931047] Wed, 03 October 2012 05:17 Go to previous messageGo to next message
the customVariant set on the column is not applied to the SortIndicator.
If you need this functionality, please file an enhancement request.
Ivan
> columnIndex);
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Set Custom Variant for TableColumn not working. [message #931528 is a reply to message #931047] Wed, 03 October 2012 05:31 Go to previous messageGo to next message
BTW... here is the bug about this issue:
362166: [Theming] Let sub-widgets inherit styles and custom variants
https://bugs.eclipse.org/bugs/show_bug.cgi?id=362166
> columnIndex);
Ivan Furnadjiev
Re: Set Custom Variant for TableColumn not working. [message #931796 is a reply to message #931528] Wed, 03 October 2012 10:34 Go to previous messageGo to next message
Thank Ivan.
Is there a workaround anyone can recommend to remove the visual indicator for a column, or hide it? I would like to not show the indicator for some columns.
Re: Set Custom Variant for TableColumn not working. [message #931893 is a reply to message #931796] Wed, 03 October 2012 12:11 Go to previous messageGo to next message
George,
what I don't understand is how did you make sort indicator visible in
multiple columns in the same time. In Table widget only one column could
be sortable - set by Table#setSortColumn and Table#setSortDirection.
Based on column selection listener you could change the sortable column
- see Controls Demo -> Table tab. Could you provide a snippet to
demonstrate the issue?
Best,
Ivan
On 10/3/2012 5:34 PM, George R Malary wrote:
> Thank Ivan.
Ivan Furnadjiev
Re: Set Custom Variant for TableColumn not working. [message #931898 is a reply to message #931893] Wed, 03 October 2012 12:20 Go to previous message
The following snippet makes the neutral sort indicator appear for all columns:
If change the previous code to the following, it works as you describe, only showing the sort indicator for the sorted column:
Sorting works as expected, and the column that is sorted shows the correct up or down image as described in the stylesheet.
Previous Topic:IE Job Queue Error with RAP 1.4.2
Next Topic:Demos
Current Time: Sat Jul 26 07:51:42 EDT 2025
Powered by FUDForum. Page generated in 0.25673 seconds
