Home » Modeling » Graphiti » Maintaing a list of BoxRelativeAnchors in a Shape
Maintaing a list of BoxRelativeAnchors in a Shape [message #931788] Wed, 03 October 2012 10:26 Go to next message
I am trying to have incoming links to end at the middle of top line of a node(e.g. rectangle) and all outgoing links to start at the middle of the buttom line of a graphical node. See in the figure, incoming links should end on A and outgoing links on B.
index.php/fa/11705/0/
How this could be done? I though of using BoxRelativeAnchors. I created two box relative anchors and added to the pictorial element of a graphical node, as below.
But I am not sure how can I set proper anchors at the start and end of a connection in the add method of add link feature i.e. in connection.setStart(??); connection.setEnd(??); ??.
public PictogramElement add(IAddContext context) {
		final BoxRelativeAnchor boxAnchorIn = peCreateService.createBoxRelativeAnchor(containerShape);
		boxAnchorIn.setRelativeWidth(0.5);
		boxAnchorIn.setRelativeHeight(0.0);
		boxAnchorIn.setReferencedGraphicsAlgorithm(roundedRectangle);
	      final Rectangle rectangle = gaService.createRectangle(boxAnchorIn);
	      rectangle.setForeground(manageColor(IdmColors.TASK_BORDER_COLOR));
	      rectangle.setBackground(manageColor(IdmColors.TASK_FILL_COLOR));
	      rectangle.setLineWidth(2);
	      gaService.setLocationAndSize(rectangle, 0, 0, 5, 5);
		final BoxRelativeAnchor boxAnchorOut = peCreateService.createBoxRelativeAnchor(containerShape);
		boxAnchorOut.setRelativeWidth(0.5);
		boxAnchorOut.setRelativeHeight(1.0);
		boxAnchorOut.setReferencedGraphicsAlgorithm(roundedRectangle);
	      final Rectangle rectangleOut = gaService.createRectangle(boxAnchorOut);
	      rectangleOut.setForeground(manageColor(IdmColors.TASK_BORDER_COLOR));
	      rectangleOut.setBackground(manageColor(IdmColors.TASK_FILL_COLOR));
	      rectangleOut.setLineWidth(2);
	      gaService.setLocationAndSize(rectangleOut, -5, -5, 5, 5);
  • Attachment: anchors.gif
    (Size: 5.54KB, Downloaded 550 times)
[Updated on: Wed, 03 October 2012 11:29] by Moderator
Re: Maintaing a list of BoxRelativeAnchors in a Shape [message #933065 is a reply to message #931788] Thu, 04 October 2012 13:45 Go to previous messageGo to next message
Hi Surja,
You would do that in the add method of your add connection feature. There you can navigate from your chopbox anchor or your shape to the right box relative anchor and set that as anchor for the new connection. This is possible for both source and target anchor.
Michael
Re: Maintaing a list of BoxRelativeAnchors in a Shape [message #933869 is a reply to message #933065] Fri, 05 October 2012 08:14 Go to previous messageGo to next message
Thanks Michael.
Again, how to use/attach custom properties(for example assign Id to each BoxRelativeAnchor in a ContainerShape) to the anchors when creating them?
I don't find any useful information on this in Javadoc for BoxRelativeAnchor.
Best Regards
Surya
Re: Maintaing a list of BoxRelativeAnchors in a Shape [message #933888 is a reply to message #933869] Fri, 05 October 2012 08:35 Go to previous message
Hi Surya,
a BoxRelativeAnchor is also a PropertyContainer and has a list attribute properties. See http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fresources%2Fdocu%2Fgfw%2Fuser-defined-properties.htm&cp=23_1_10 for details on user defined properties.
Michael
Previous Topic:Setting BoxRelativeAnchor at the source of ConnectionContext does work!!
Next Topic:Graphiti framework and decorators
Current Time: Sat Jul 26 21:24:18 EDT 2025
Powered by FUDForum. Page generated in 0.04499 seconds
