Home » Newcomers » Newcomers » Problem with Dynamic Web Project
Problem with Dynamic Web Project [message #930787] Tue, 02 October 2012 12:41 Go to next message
I have a Dynamic Web Project, which uses JSP and static HTML. I did not touch this project for a longer time. Maybe I updated eclipse/java/tomcat components in the meantime.
When I now call "Run on Server", the following exception is printed in the console:
Oct 2, 2012 6:33:15 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/server:/usr/lib/jvm/java-6-openjdk/jre/lib/amd64:/usr/lib/jvm/java-6-openjdk/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib/jni:/lib:/usr/lib
Oct 2, 2012 6:33:16 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:Bavaria 64' did not find a matching property.
Oct 2, 2012 6:33:16 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Oct 2, 2012 6:33:16 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 711 ms
Oct 2, 2012 6:33:16 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Oct 2, 2012 6:33:16 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.29
Oct 2, 2012 6:33:16 PM org.apache.catalina.core.StandardContext resourcesStart
SEVERE: Error starting static Resources
java.lang.IllegalArgumentException: Document base /home/wagner/dvl/prj/.metadata/.plugins/org.eclipse.wst.server.core/tmp0/wtpwebapps/Bavaria 64 does not exist or is not a readable directory
	at org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:142)
	at org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4249)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4418)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:785)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:445)
	at org.apache.catalina.core.StandardService.start(StandardService.java:519)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:581)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Oct 2, 2012 6:33:16 PM org.apache.catalina.core.StandardContext start
SEVERE: Error in resourceStart()
SEVERE: Error getConfigured
SEVERE: Context [/b64] startup failed due to previous errors
Oct 2, 2012 6:33:16 PM org.apache.catalina.core.StandardContext stop
INFO: Container org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/b64] has not been started
Oct 2, 2012 6:33:16 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Oct 2, 2012 6:33:16 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Oct 2, 2012 6:33:16 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/24  config=null
Oct 2, 2012 6:33:16 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 290 ms
However, when I create a new Dynamic Web Project, I do not get this error. But I would like to avoid to "solve" this problem by moving to a new project.
What can I do?
Thank you!
Magnus
Re: Problem with Dynamic Web Project [message #930803 is a reply to message #930787] Tue, 02 October 2012 12:53 Go to previous messageGo to next message
On 10/2/2012 10:41 AM, Magnus Warker wrote:
> Hello,
> [snip]
> What can I do?
> Thank you!
> Magnus
Magnus,
Eclipse has a separate and special web tools platform forum for your
support! Ask there.
Re: Problem with Dynamic Web Project [message #931303 is a reply to message #930803] Wed, 03 October 2012 00:46 Go to previous messageGo to next message
I have posted it in WTP, but there is no response yet.
What other places would be ok? Are there other eclipse forums or newsgroups?
I am looking for a solution for a long time now...
Magnus
Re: Problem with Dynamic Web Project [message #931773 is a reply to message #931303] Wed, 03 October 2012 10:05 Go to previous messageGo to next message
On 10/2/2012 10:46 PM, Magnus Warker wrote:
> newsgroups?
> Thanks
> Magnus
I'd like to help but I don't know what this "Bavaria 64" thing is. I'm
suspicious of ever putting spaces in pathnames even on platforms like
Windows and Macintosh when these are involved in any way whatsoever with
software development. (I don't mind using spaces in the name of a letter
to my aunt Martha I'm writing in OpenOffice Writer, for example.)
I would rid myself of this "Bavaria 64" thing and choose a different
name. I'm assuming you have control over that because of where it
appears in your paths. I'm guessing it's your name and not something
imposed on you by some framework. You may or may not have something to
change in WebContent/WEB-INF/web.xml afterward. If it's display-name,
you don't have to change it if you don't want to since that doesn't matter.
Next, I'd clear Eclipse's Tomcat stuff. Right-click in the Servers view
on your Tomcat, choose Add and Remove, double-click whatever became of
"Bavaria 64" (which will put it into the Available pane) and click
Finish. Then right-click Tomcat and do Clean. Then add your project back
using Add and Remove and Start/Debug it.
If you still get this error, I'd begin investigating the actual path
complained about. Go to that path and make certain it exists, that
permissions are good, etc. Normally, none of these things should be
problematic since Eclipse always does the right thing when it deploys
internally to the Tomcat you told it to use.
I've stopped monitoring webtools. If you have more questions and can't
get help there, ask me directly or in here and we can see from there.
Russ Bateman
P.S. The INFO complaint about "optimal performance" is mostly a red
herring. Don't sweat that.
Re: Problem with Dynamic Web Project [message #934667 is a reply to message #931773] Sat, 06 October 2012 02:47 Go to previous message
Dear Russel!
It works, thanks a lot!!!
Magnus
Russell Bateman wrote on Wed, 03 October 2012 10:05
I'm
I do this for years now on different platforms and it never caused a problem. But you are right, one should consider this when trying to find out what's wrong.
This was the solution! After doing this it worked again.
What's is going on behind the GUI when doing these steps?
Thanks again!
Magnus
Previous Topic:Android XML Editor missing Graphical and Source tabs at bottom
Next Topic:Installing Google GWT on Juno 4.2
Current Time: Sun Jul 27 06:38:50 EDT 2025
Powered by FUDForum. Page generated in 0.08262 seconds
