Home » Eclipse Projects » Remote Application Platform (RAP) » IE Job Queue Error with RAP 1.4.2(Flushing job queue (childrensignals#5) failed error under IE)
IE Job Queue Error with RAP 1.4.2 [message #930707] Tue, 02 October 2012 11:04 Go to next message
Hi guys,
we've got this issue with IE versions 8 and 9 where we get the following error:
Flushing job queue (childrensignals#5) failed Invalid argument
This results when the user starts vertically resizing one of our workbench views, the mouse pointer leaves the browser window and then reenters it after the user has released the mouse button.
I am not entirely sure how and why, but I tracked the issue down to the method
qx.ui.form.TextField._syncFieldHeight
It appears that the following code attempts to set a negative height for the element since the inner height of the widget is 0:
this._inputElement.style.height = (this.getInnerHeight() - 2) + "px";
We've patched this with
Math.max
in our qooxdoo sources but we don't like the solution, any ideas how we get rid of the issue without modifying the qooxdoo sources?
Best regards
Re: IE Job Queue Error with RAP 1.4.2 [message #931516 is a reply to message #930707] Wed, 03 October 2012 05:21 Go to previous message
you could check if the issue still persists in RAP 1.5/1.5.1. If it's
still valid, than please open a bugzilla and attach a snippet to
reproduce it.
Ivan
On 10/2/2012 6:04 PM, tibersept Mising name wrote:
> Hi guys,
> following error:
> the method qx.ui.form.TextField._syncFieldHeight It appears that the
> We've patched this with Math.max in our qooxdoo sources but we don't
> Best regards
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:Java-Version of WAR product
Next Topic:Set Custom Variant for TableColumn not working.
Current Time: Mon Jul 21 00:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.04799 seconds
