[CDO] Repository recovery fails after crash with stanalone CDO sever with postgresql [message #931515] |
Wed, 03 October 2012 05:25  |
for some reason I have a standalone CDO server that crashed. So I restarted it and now I get the following error :
Exception in thread "main" org.eclipse.net4j.db.DBException: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getMaxID(ObjectTypeTable.java:185)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTypeMapper.getMaxID(DelegatingObjectTypeMapper.java:85)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.repairAfterCrash(AbstractHorizontalMappingStrategy.java:94)
at org.eclipse.emf.cdo.server.internal.db.DBStore.repairAfterCrash(DBStore.java:679)
at org.eclipse.emf.cdo.server.internal.db.DBStore.reStart(DBStore.java:661)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:556)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1845)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:208)
at ch.paranor.reverse.specification.server.CDOServer.start(CDOServer.java:230)
at ch.paranor.reverse.specification.server.CDOServer.main(CDOServer.java:275)
Caused by: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getMaxID(ObjectTypeTable.java:174)
... 15 more
It happen when running the following SQL statement :
SELECT MAX(cdo_id) FROM cdo_objects;
So I tried to run in from the psql util :
max
73
(1 row)
It works fine... so I thought it was the JDBC driver version that was not up to date. My 8.44 server is 9.1. I was using the JDBC driver v3 for postgresql 8.4. I moved to JDBC driver v3 for postgresql 9.1. But I still have the same issue.
Any idea of how I can recover this repository ?
regards,
Yvan.
FUDForum. Page generated in 0.05044 seconds
