| EmptyStackException can occur when undoing using the keyboard shortcuts [message #93103] |
Tue, 09 September 2003 10:58  |
sometimes when the user does too much CTRL+Z, an EmptyStackException is
thrown. I found that the implementation of UndoAction is missing the call to
CommandStack.canUndo. I know that there is a call to this method in the
method calculateEnabled of the UndoAction, but it seems that this method is
not called when it is activated from the keyboard (i.e., using CTRL+Z).
Please let me know if i am missing something here, since as for now I've
fixed it locally in my app.
thanks
Yoav
| Re: EmptyStackException can occur when undoing using the keyboard shortcuts [message #93147 is a reply to message #93138] |
Tue, 09 September 2003 12:10   |
Hi, i can't reproduce it in the logic example, but i guess it is somehow
related to my previous post, regarding the problems with undo/redo, it seems
that both of this post problem and the previous one have the same "root", so
i can't reproduce it in other apps, but in the other post there are other
symptoms...
thanks
Yoav
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bjkt18$80o$1@eclipse.org...
> I can't reproduce this problem. The same UndoAction is used for both
> keyboard shortcuts and toolbar/menu items. If the UndoAction is not
> enabled, the keyboard shortcut shouldn't work. Can you give a
> step-by-step test case?
> Eric
> Yoav Rubin wrote:
> > Hi
call to
is
> > thanks
> > Yoav
| Re: EmptyStackException can occur when undoing using the keyboard shortcuts [message #93270 is a reply to message #93103] |
Wed, 10 September 2003 10:10   |
It is likely that your instance of UndoAction is not listening to the
CommandStack. I've guessing that if you drop-down the Edit menu, Eclipse is
unnecessarily querying your isEnabled() state, which causes the action to
disable. What should happen, is when the command stack undoes a command, it
notifies a listener immediately, that listener then calls update() on the
command stack actions (undo and redo). I think this is also linked to the
dirty state of the editor.
-Randy
"Yoav Rubin" <yoav@il.ibm.com> wrote in message
news:bjkpr7$4td$1@eclipse.org...
> Hi
to
is
> thanks
> Yoav
| Re: EmptyStackException can occur when undoing using the keyboard shortcuts [message #93688 is a reply to message #93270] |
Thu, 11 September 2003 03:36  |
Thanks Randy, your "diagnosis" solved the problem :)
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bjnbab$lms$1@eclipse.org...
is
it
> -Randy
> > Hi
call
> to
> is
> > thanks
> > Yoav
FUDForum. Page generated in 0.04866 seconds
