Home » Eclipse Projects » Eclipse Platform » Help on Capturing Max or Min event of Editor
Help on Capturing Max or Min event of Editor [message #91934] Fri, 11 July 2003 13:12 Go to next message
Hi. My Editor needs to do somethings when it is being Maximized/Restore.
Can somebody point me the the classes and the methods that I need to
extends/override.
To Maximize an editor u normal just double click on the header of the
editor. To restored to non-maximized you can double click on the header of
the editor again.
Re: Help on Capturing Max or Min event of Editor [message #92052 is a reply to message #91934] Fri, 11 July 2003 14:27 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
There is no API to do that
Simon :-)
"Chinh Hoang" <choang@ca.ibm.com> wrote in message
news:bemr69$591$1@eclipse.org...
> extends/override.
> the editor again.
> Thanks
Re: Help on Capturing Max or Min event of Editor [message #93078 is a reply to message #92052] Mon, 14 July 2003 09:53 Go to previous messageGo to next message
Are there any plans to? The reason why I trying to listen to these events
or some how extend that code is because i am implementing a feature for my
editor that understands when to put its palette inside of the pallette
viewer when the palette viewer is visible or inside the editor inside the
edtitor itself when the palette viewer is not.
> Simon :-)
> > extends/override.
> > the editor again.
> > Thanks
Re: Help on Capturing Max or Min event of Editor [message #93092 is a reply to message #93078] Mon, 14 July 2003 10:08 Go to previous message
No plan to add this type of API. You can open a bug report against
Platform - UI to make your request. Include a detail description of your use
case (maybe with a couple of screen shots)
Simon :-)
news:beuckr$tko$1@eclipse.org...
> > Simon :-)
Maximized/Restore.
> > > extends/override.
header of
> > > the editor again.
> > > Thanks
Previous Topic:How can I use the font "courier new" under Linux with GTK?
Next Topic:Usability regression 2.0->2.1 - Shells disappear during ALT+TAB
Current Time: Thu Jul 24 17:21:32 EDT 2025
Powered by FUDForum. Page generated in 0.04673 seconds
