Home » Modeling » TMF (Xtext) » Headless ANT build
Headless ANT build [message #930388] Tue, 02 October 2012 05:14 Go to next message
is it possible to headless build a simple Xtext project with Ant (without eclipse and without Maven)?
Following:
<java classpathref="xtend-compiler" classname="org.eclipse.xtend.core.compiler.batch.Main" fork="true" failonerror="yes">
<arg value="-encoding"/>
<arg value="UTF-8"/>
<arg value="-d"/>
<arg value="ant/xtend-src"/>
<arg value="-cp"/>
<arg value="${libs}/org.eclipse.xtext_2.3.1.v201208210947.jar; ..."/>
<arg value="src-gen"/>
<arg value="src"/>
</java>
but it ends with an endless flow of exceptions starting with
[java] 0 ERROR AbstractClassMirror - resource is empty: java:/Objects/org.eclipse.xtext.generator.IGenerator
[java] 0 [main] ERROR org.eclipse.xtext.common.types.access.impl.AbstractClassMirror - resource is empty: java:/Objects/org.eclipse.xtext.generator.IGenerator
[java] 16 ERROR LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.0.1::3::/2' failed.
[java] java.lang.IllegalStateException: Resource has not been loaded
[java] at org.eclipse.xtext.common.types.access.impl.ClasspathTypeProvider.findTypeByClass(ClasspathTypeProvider.java:128)
[java] at org.eclipse.xtext.common.types.access.impl.ClasspathTypeProvider.findTypeByName(ClasspathTypeProvider.java:82)
[java] at org.eclipse.xtext.common.types.xtext.AbstractTypeScope.getSingleElement(AbstractTypeScope.java:54)
[java] at org.eclipse.xtext.scoping.impl.AbstractScope.getSingleElement(AbstractScope.java:105)
[java] at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:121)
[java] at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:179)
[java] at org.eclipse.xtext.xbase.resource.XbaseResource.access$0(XbaseResource.java:1)
[java] at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:239)
[java] at org.eclipse.xtext.xbase.resource.XbaseResource$2.exec(XbaseResource.java:1)
[java] at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:124)
[java] at org.eclipse.xtext.xbase.resource.XbaseResource.getEObject(XbaseResource.java:237)
[java] at org.eclipse.xtend.core.resource.XtendResource.getEObject(XtendResource.java:82)
[java] at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:219)
[java] at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
[java] at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:263)
[java] at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1483)
[java] at org.eclipse.xtend.core.xtend.impl.XtendImportImpl.getImportedType(XtendImportImpl.java:212)
Thank you!!
PS
It also look's like only the last source directory get considered by the Xtend compiler. The reverse sequence ('src' than 'src-gen') ends with
[java] 0 INFO XtendBatchCompiler - No sources to compile in 'src-gen'
[java] 0 [main] INFO org.eclipse.xtend.core.compiler.batch.XtendBatchCompiler - No sources to compile in 'src-gen'
Re: Headless ANT build [message #930503 is a reply to message #930388] Tue, 02 October 2012 07:32 Go to previous messageGo to next message
Hi Boris,
could you please attach your project as zip?
Dennis.
Re: Headless ANT build [message #930608 is a reply to message #930503] Tue, 02 October 2012 09:33 Go to previous messageGo to next message
The test project is in the headless-build-problem.zip.
Since only max. 2 MB files are allowed, I removed the eclipse plugins from the
org.xtext.example.mydsl/lib
directory. The jar files upon antlr generator were copied from the eclipse/plugins directory:
antlr-generator-3.2.0.jar
com.google.guava_10.0.1.v201203051515.jar
com.google.inject_3.0.0.v201203062045.jar
com.ibm.icu_4.4.2.v20110208.jar
javax.inject_1.0.0.v20091030.jar
org.antlr.runtime_3.2.0.v201101311130.jar
org.apache.commons.cli_1.2.0.v201105210650.jar
org.apache.commons.logging_1.0.4.v201101211617.jar
org.apache.log4j_1.2.15.v201012070815.jar
org.eclipse.emf.codegen.ecore_2.7.0.v20120130-0943.jar
org.eclipse.emf.codegen_2.6.0.v20120130-0943.jar
org.eclipse.emf.common_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122.jar
org.eclipse.emf.ecore_2.7.0.v20120127-1122.jar
org.eclipse.emf.mwe.core_1.2.1.v201206110920.jar
org.eclipse.emf.mwe.utils_1.2.1.v201206110920.jar
org.eclipse.emf.mwe2.language_2.3.0.v201206120758.jar
org.eclipse.emf.mwe2.launch_2.3.0.v201206120758.jar
org.eclipse.emf.mwe2.lib_2.3.0.v201206110920.jar
org.eclipse.emf.mwe2.runtime_2.3.0.v201206110920.jar
org.eclipse.jdt.core_3.7.0.v_B61.jar
org.eclipse.xpand_1.2.0.v201206110941.jar
org.eclipse.xtend.core_2.3.1.v201208210947.jar
org.eclipse.xtend.lib_2.3.1.v201208210947.jar
org.eclipse.xtend.typesystem.emf_1.2.0.v201206110941.jar
org.eclipse.xtend_1.2.0.v201206110941.jar
org.eclipse.xtext.common.types_2.3.1.v201208210947.jar
org.eclipse.xtext.generator_2.3.1.v201208210947.jar
org.eclipse.xtext.util_2.3.1.v201208210947.jar
org.eclipse.xtext.xbase.lib_2.3.1.v201208210947.jar
org.eclipse.xtext.xbase_2.3.1.v201208210947.jar
Versions:
- Eclipse
- Eclipse Java EE IDE for Web Developers.
- Version: Indigo Release
- Build id: 20110615-0604
- Xtext 2.3.1
My build.xml:
<project name="project" default="all">
<property name="workflow" value="src/org/xtext/example/mydsl/GenerateMyDsl.mwe2" />
<path id="wme2-classpath">
<fileset dir="lib" includes="*.jar" />
<pathelement location="src"/>
</path>
<path id="xtend-compiler-classpath">
</path>
<target name="compile">
<mkdir dir="ant" />
<mkdir dir="ant/xtend-src" />
<java classpathref="xtend-compiler-classpath" classname="org.eclipse.xtend.core.compiler.batch.Main" fork="true" failonerror="yes">
<arg value="-encoding" />
<arg value="UTF-8" />
<arg value="-d" />
<arg value="ant/xtend-src" />
<arg value="-cp" />
<arg value="lib/org.eclipse.xtext_2.3.1.v201208210947.jar" /> <!-- Here come more libraries -->
<arg value="src-gen" />
<arg value="src" />
</java>
</target>
<target name="run-workflow">
<java classpathref="wme2-classpath" classname="org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher" fork="true" failonerror="yes">
<jvmarg value="-Dfile.encoding=UTF-8" />
<arg value="${workflow}" />
</java>
</target>
<target name="all" depends="run-workflow,compile" description="Build all">
</target>
</project>
The single lib/org.eclipse.xtext_2.3.1.v201208210947.jar file on the Xtend compiler class path produces the exceptions.
Thank you for the help!
Re: Headless ANT build [message #930641 is a reply to message #930608] Tue, 02 October 2012 10:02 Go to previous messageGo to next message
Hi Boris,
first of all, you can use our standalone uber jar, it contains most of the needed eclipse stuff it's about 10 mb big.
Here is the latest SNAPSHOT: http://build.eclipse.org/common/xtend/maven/org/eclipse/xtend/org.eclipse.xtend.standalone/2.4.0-SNAPSHOT/
Second, class path entries have to be separated by the java.io.File.pathSeparatorChar char, the same is true for the last argument, which is the source folder/-s argument. In unix filesystems following works for me (I call the compile target directly without mwe2 stuff):
<arg value="lib/org.eclipse.xtext.xbase.lib_2.4.0.v201210011132.jar:lib/org.eclipse.xtend.standalone-2.4.0-20120828.110609-1.jar" />
<arg value="src-gen:src" />
Dennis.
[Updated on: Tue, 02 October 2012 10:03] by Moderator
Re: Headless ANT build [message #935228 is a reply to message #930388] Sat, 06 October 2012 16:52 Go to previous messageGo to next message
Hello Dennis,
thank you very much for the help. It works!
My problem was to understand, that the exception
- java.lang.IllegalStateException: Resource has not been loaded
just means, that the class can't be loaded, while some other required class isn't on the class path.
The tip with the "src:src-gen" was also very helpful.
Best Regards,
Boris Brodski
PS
I just recorded a screen cast (XtextCast) about building Xtext projects with Ant:
xtextcasts.org(SLASH)episodes/12-building-with-ant
Re: Headless ANT build [message #935243 is a reply to message #935228] Sat, 06 October 2012 17:11 Go to previous messageGo to next message
Hello Dennis,
Here is the URL again: http://xtextcasts.org/episodes/12-building-with-ant
Boris
[Updated on: Sat, 06 October 2012 17:12] by Moderator
Re: Headless ANT build [message #1265182 is a reply to message #935243] Wed, 05 March 2014 14:56 Go to previous message
Hi Brodski,
I Need small help, the headless build we can run easily if it is in the current working directory, lets assume if i want to run my build file out of that particular directory can you just point me where exactly i need to change the paths( I was bit confused while doing that) your help is appreciated. Here is the folder structure of my project
sample(folder)--
|- org.xtext.sample
|- org.xtext.sample.ui
|- org.xtext.sample.sdk and test project
|- build.xml
I have written the build.xml file out side the Xtext project that means in the sample folder. so i am not very sure where to change this things.
Thanks.
Previous Topic:How to complete code using ctrl-space
Next Topic:[Xtend2] for non xtext model
Current Time: Fri Jul 18 14:21:02 EDT 2025
Powered by FUDForum. Page generated in 0.04574 seconds
