Home » Archived » Visual Editor (VE) » Painting an SWT Table
Painting an SWT Table [message #93027] |
Mon, 06 June 2005 13:14  |
Originally posted by: tcnesham.email.uophx.edu
------=_NextPart_000_0068_01C56A91.40813960
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I dropped a table into the VE shell painter and that worked correctly. =
But after I added a new constructor and added some methods the table =
object appears below the shell frame. I want to add some code to the =
class that contains the table, is there a preferred way to do this? =
Should I extend the table/class and add my code there? Is there a bug? =
Perhaps I am mixing the wrong versions? I should mention that I have =
MyEclipse installed. Are these the correct versions to match together?
Eclipse Java Development Tools Version: 3.0.2
Java EMF Model Version: 1.0.2
Visual Editor Version: 1.0.2=20
Eclipse Graphical Editing Framework 3.0.1
EMF Service Data Objects (SDO) Version: 2.0.1
Eclipse Modeling Framework (EMF) Version: 2.0.1
TIA,
Tim
--=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1491" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I dropped a table into the VE shell =
painter and=20
that worked correctly. But after I added a new constructor and =
added some=20
methods the table object appears below the shell frame. I want to =
add some=20
code to the class that contains the table, is there a preferred way to =
do this?=20
Should I extend the table/class and add my code there? Is there a =
bug?=20
Perhaps I am mixing the wrong versions? I should mention that I =
have=20
MyEclipse installed. Are these the correct versions to match=20
together?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Eclipse Java Development Tools Version: =
3.0.2<BR>Java EMF Model Version: 1.0.2<BR>Visual Editor Version: 1.0.2=20
<BR>Eclipse Graphical Editing Framework 3.0.1<BR>EMF Service Data =
Objects (SDO)=20
Version: 2.0.1<BR>Eclipse Modeling Framework (EMF) Version:=20
2.0.1<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>TIA,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Tim</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><BR>-- <BR></FONT></DIV></BODY></HTML>
------=_NextPart_000_0068_01C56A91.40813960--
Re: Painting an SWT Table [message #93055 is a reply to message #93042] |
Mon, 06 June 2005 15:02   |
As I mentioned, when I bring this up in the VE painter the table object is
actually below a sort of "shadow" of itself. I cannot visually move it
around. I added public PlayersTable(Shell parent, Td td) and run().
Attached are all the files, nothing proprietary.
* Created on Jun 4, 2005
package td;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
* @author tcnesham
public class PlayersTable extends Composite
private Button new_button = null;
private Button delete_button = null;
private Shell sShell;
private Td td;
private Display display;
private Table table = null; //
@jve:decl-index=0:visual-constraint="95,149"
* Custom Constructor
* @param parent
* @param td
super(parent, SWT.PRIMARY_MODAL);
this.td = td;
initialize();
* Constructor created by painter
* @param parent
* @param style
public PlayersTable(Composite parent, int style)
super(parent, style);
initialize();
private void initialize()
new_button = new Button(this, SWT.NONE);
delete_button = new Button(this, SWT.NONE);
createTable();
new_button.setBounds(new org.eclipse.swt.graphics.Rectangle(519, 387,
76, 32));
new_button.setText("New");
delete_button.setBounds(new org.eclipse.swt.graphics.Rectangle(601, 387,
76, 32));
delete_button.setText("Delete");
setSize(new org.eclipse.swt.graphics.Point(772, 461));
public void run()
display = new Display();
sShell.open();
while (!sShell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
* This method initializes table
private void createTable() {
table = new Table(this, SWT.BORDER);
table.setFont(new
org.eclipse.swt.graphics.Font(org.eclipse.swt.widgets.Displa y.getDefault(),
"Arial", 10, org.eclipse.swt.SWT.NORMAL));
table.setBounds(new org.eclipse.swt.graphics.Rectangle(54,53,572,156));
} // @jve:decl-index=0:visual-constraint="65,-170"
Timothy C. Nesham
School: tcnesham@email.uophx.edu
Work: tcnesham@cvty.com
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:d8215u$8p1$1@news.eclipse.org...
> Could you please paste a copy of the code that got generated? That would
> help to see what you were trying to do.
Attachment: td.zip
(Size: 22.92KB, Downloaded 162 times)
Re: Painting an SWT Table [message #93115 is a reply to message #93086] |
Mon, 06 June 2005 17:35  |
Great! That did the trick. I should have guessed I could simply call
getShell() without declaring a variable.
Timothy C. Nesham
news:d82dhq$pdp$1@news.eclipse.org...
> You found a very interesting bug in 1.0.2. It works ok in our latest
> development drivers of VE 1.1.
> The fix is simple, get rid of sShell. It gets confused with the shell.
> You really don't want the shell there anyway because the run shouldn't
> be done on an instance of the class.
> Rich Kulp
Re: Painting an SWT Table [message #607891 is a reply to message #93027] |
Mon, 06 June 2005 13:29  |
> TIA,
> Tim
Rich Kulp
Re: Painting an SWT Table [message #607892 is a reply to message #93042] |
package td;
* @author tcnesham
private Td td;
* @param parent
* @param td
this.td = td;
initialize();
* @param parent
* @param style
initialize();
createTable();
76, 32));
76, 32));
public void run()
sShell.open();
display.sleep();
display.dispose();
table.setFont(new
Timothy C. Nesham
Attachment: td.zip
(Size: 22.92KB, Downloaded 124 times)
Re: Painting an SWT Table [message #607894 is a reply to message #93055] |
Mon, 06 June 2005 17:00  |
Rich Kulp
Re: Painting an SWT Table [message #607896 is a reply to message #93086] |
Timothy C. Nesham
> Rich Kulp
Current Time: Fri Jul 18 17:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.48621 seconds
