Home » Newcomers » Newcomers » Ctrl+shift+o not working correctly
Ctrl+shift+o not working correctly [message #930286] Tue, 02 October 2012 03:09 Go to next message
When I use ctrl+shift+o, import adds "src." to what I expect.
Like, if I expect
import com.xyz;
ctrl+shift+o gives me
import src.com.xyz;
Please tell me whats the reason.
Manish
Re: Ctrl+shift+o not working correctly [message #930304 is a reply to message #930286] Tue, 02 October 2012 03:29 Go to previous messageGo to next message
Manish,
If you look at the Properties of your Java project and in particular at
the Java Build Path's Source tab, it should point at your src folder,
not at the parent of that folder; otherwise all path segments, including
that src segment, will be interpreted as part of the qualified package name.
On 02/10/2012 9:09 AM, manish chandra wrote:
> Like, if I expect
> import com.xyz;
> import src.com.xyz;
> Manish
Re: Ctrl+shift+o not working correctly [message #930309 is a reply to message #930304] Tue, 02 October 2012 03:35 Go to previous message
Thanks a lot Ed.
Manish
Previous Topic:JSP Editor Problem..
Next Topic:Referenced projects and code assist
Current Time: Fri Jul 25 09:09:16 EDT 2025
Powered by FUDForum. Page generated in 0.09462 seconds
