Home » Eclipse Projects » GEF » Check if key currently is pressed
Check if key currently is pressed [message #922995] Tue, 25 September 2012 10:20 Go to next message
Been searching around for a way to check if a key is pressed at a certain instance, but the only thing i can find is where you add a listener to listen when a key is pressed. I do not know if this depends on my lack of search skills or whatever. Hope someone can shine some light on this problem for me. Again:
Is there any way to check if a key is pressed or not?
Br.
Martin
Re: Check if key currently is pressed [message #930053 is a reply to message #922995] Mon, 01 October 2012 21:36 Go to previous messageGo to next message
Hi Martin,
I have custom GEF editor and some predefined shortcuts. For example if user will press "L" - connection tool become active, "P" - pan tool etc.
For this purposes I am using EditDomain methods:
EditDomain:mouseUp(MouseEvent mouseEvent, EditPartViewer viewer)
EditDomain:mouseDown(MouseEvent mouseEvent, EditPartViewer viewer)
Perhaps there are other ways for this purposes but this way works fine for me.
Igor
Re: Check if key currently is pressed [message #932884 is a reply to message #922995] Thu, 04 October 2012 10:33 Go to previous message
Martin Mising name wrote on Tue, 25 September 2012 16:20
It depends. In which situation do you need that information?
Previous Topic:ImageFigure with label
Next Topic:D'n'D from one gef editor to another one
Current Time: Wed Jul 23 05:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.26881 seconds
