Home » Newcomers » Newcomers » for/in
for/in [message #92913] Sat, 06 August 2005 17:15 Go to next message
Originally posted by: ath1931.yahoo.com
Hi all,
Is Eclipse 3.1 using Java 5.0? I tried writing a for/in statement (as
noted in "Java In A Nutshell"), but Eclipse gives me an error.
Albert
Re: for/in [message #92930 is a reply to message #92913] Sat, 06 August 2005 18:13 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
Albert Huang wrote:
> Hi all,
> Albert
What does your code look like..
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: for/in [message #92945 is a reply to message #92913] Sat, 06 August 2005 19:35 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Albert,
Have you set your compiler compliance level to 1.5? Go to
Window->Preferences->Java->Compiler and change the Compiler compliance
level to 1.5, in order to use the new language constructs introduced in
Java 5.0.
Hope this helps,
- Jeff
Albert Huang wrote:
> Hi all,
> Albert
Re: for/in [message #92972 is a reply to message #92945] Sat, 06 August 2005 21:23 Go to previous message
Thanks for all your guys' help. Jeff, you were right on the money, I just
installed it and the default version was 1.4 . I set it to 5.0 and it's
working now. Thanks for all your help again. :)
Previous Topic:project messed up
Next Topic:procedure entry point _JVM_SupportsCX8@0 not found in jvm.dll
Current Time: Tue Jul 29 01:30:41 EDT 2025
Powered by FUDForum. Page generated in 0.10960 seconds
