Home » Eclipse Projects » Eclipse 4 » XWT and Custom Widget
XWT and Custom Widget [message #929429] Mon, 01 October 2012 09:03 Go to next message
Hi! I am still playing arround with xwt more or less successfull.
I am trying to build a custom Text Widget which has already some text auto completion available.
The widget looks more or less like this:
ContentAssist Text extends Text {
private List<String> proposals;
protected void checkSubclass() {
public void setProposals(List<String> proposals) {
public List<String> getProposals() {
 return proposals:
in my xwt:
<z:ContentassistText proposals="{Binding path=defaultRoles}"/>
I have another combo where the binding with defaultRoles works perfect when i set it as input. Also the setter-method in my widget-class is called but the problem is that i always get an array with the binding data instead of the strings.
So do i have to look up the binding my self? I thought i should get the List without any trouble. By the way defaultRoles has a List<String> in the background.
I had another widget where i only bound a String and there it was easy.
Thanks for any help and
best regards weinma
Re: XWT and Custom Widget [message #929757 is a reply to message #929429] Mon, 01 October 2012 14:40 Go to previous messageGo to next message
What do you mean by "i always get an array with the binding data"? The internal Binding object?
Jürgen Weinberger wrote on Mon, 01 October 2012 09:03
 return proposals:
in my xwt:
best regards weinma
Re: XWT and Custom Widget [message #930197 is a reply to message #929757] Tue, 02 October 2012 01:16 Go to previous messageGo to next message
Sorry, if i was a little unclear.
If i look in the DebugMode at a breakpoint in my
than proposals contains an ArrayList with only one element from type org.eclipse.e4.xwt.internal.core.Binding and not a list of Strings as expected. I wonder how this is solved with the Table-, Combo-, TreeViewers where i can set a List of Strings as Input without any problems.
best Regards
Weinma
Re: XWT and Custom Widget [message #930290 is a reply to message #930197] Tue, 02 October 2012 03:16 Go to previous message
Hey! Just an update. I tried it with
public void setProposal(Object object) {
and just changed the type to Object at my CustomWidget
So now i get an correct ArrayList<Object> with the Strings and just have to do some type checks and casts.
My last question is if this is the way to do something like this or is it possible to get the a list with the right typesafe data?
Best regards
Weinma
[Updated on: Tue, 02 October 2012 03:16] by Moderator
Previous Topic:Quick Context View from Navigate Menu
Next Topic:After Juno SR1 the Wizard "Eclipse 4 Application Project" misses adding plugins
Current Time: Wed Jul 23 07:45:23 EDT 2025
Powered by FUDForum. Page generated in 0.08663 seconds
