Home » Modeling » Epsilon » EGL only write file on changes
EGL only write file on changes [message #929080] Mon, 01 October 2012 03:48 Go to next message
Is it (easily) possible to let EGL only write the file if it actually changed? (Assumming it as already generated earlier)
For larger projects my C++ code generation results in lots and lots of source files. After a minor change in the model, code generation rewrites all files.
Resulting in make recompiling all files, eventhough most of them are unchanged...
Maarten
Re: EGL only write file on changes [message #929365 is a reply to message #929080] Mon, 01 October 2012 07:53 Go to previous messageGo to next message
Hi Maarten,
That shouldn't be too difficult to fix. Could you perhaps file an enhancement request for this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT.Epsilon
Of course, any contributions in this direction would clearly help speed things up Smile
Dimitris
Re: EGL only write file on changes [message #929389 is a reply to message #929365] Mon, 01 October 2012 08:16 Go to previous messageGo to next message
Dimitris Kolovos wrote on Mon, 01 October 2012 13:53
If you could point me to to the class which is responsible for loading/writing generated files I could give it a try Smile
Re: EGL only write file on changes [message #929398 is a reply to message #929389] Mon, 01 October 2012 08:28 Go to previous messageGo to next message
Thanks! The doGenerate/write methods of /org.eclipse.epsilon.egl.engine/src/org/eclipse/epsilon/egl/EglFileGeneratingTemplate.java should be a good starting point for this. So that the engine doesn't have to remember what it generated and what not I'd be inclined to read the contents of the existing file, compare it with the output and only overwrite if different.
Re: EGL only write file on changes [message #929587 is a reply to message #929398] Mon, 01 October 2012 11:33 Go to previous messageGo to next message
Patch submitted: Bug #390836
It was a pain in the *** to test it, as I use the official released version (so my users are able to easily obtain Epsilon). This version is very outdated, especially package name changes took quite some time to solve.
Is there any plan to provide a new official release? (lots of cool feature have been added lately, so I cannot wait to use that version in my application!)
Re: EGL only write file on changes [message #929633 is a reply to message #929587] Mon, 01 October 2012 12:18 Go to previous messageGo to next message
Hi Maarten,
Thanks. Yes, 1.0 will be released within the next few days.
Dimitris
Re: EGL only write file on changes [message #929868 is a reply to message #929633] Mon, 01 October 2012 16:59 Go to previous message
Excellent news!
Previous Topic:PeriodicallyUpdateEPackageRegistryMonitorJob eats away heap
Next Topic:[EOL] Model Loading Errors
Current Time: Sat Jul 26 11:30:54 EDT 2025
Powered by FUDForum. Page generated in 0.06663 seconds
