Home » Modeling » GMF (Graphical Modeling Framework) » dyanamic addition of new shape to the palette at runtime.
dyanamic addition of new shape to the palette at runtime. [message #92316] Sat, 13 January 2007 00:44 Go to next message
Originally posted by: imrannawaz.softtrans.net
Thanks Alex,
That link help in extending the palette but not at run time.
But I want at runtime means when u run the application using run as..
Eclipse Application.
There i want to add palette dynamically to the exiting palette.
I wonder if there is a way to add dynamically new components to the GMF
palette without having to regenerate code every time.
thanks
Imran
Re: dyanamic addition of new shape to the palette at runtime. [message #92928 is a reply to message #92316] Mon, 15 January 2007 13:29 Go to previous message
Hello IMRAN,
Do you mean, then diagram editor is opened you have to change palette contents
on receiving some events from UI? Otherwise AFAIU you can implement your
custom PaletteProvider to dynamically fill the palette contents.
Alex Shatalin
Previous Topic:Decorator provider problem
Next Topic:Adding more tabs in property view in GMF
Current Time: Sun Jul 27 03:24:28 EDT 2025
Powered by FUDForum. Page generated in 0.17385 seconds
