Home » Eclipse Projects » GEF » Connections in Liinux
Connections in Liinux [message #92923] Mon, 08 September 2003 17:56 Go to next message
Originally posted by: gg.decisionsoft.co.uk
I am writing a program to display a tree using GEF.
However when I run under linux, maximizing the editor sometimes causes all the connections to be come disconnected.
They keep their size and shape, but are not in the correct place. It does not happen all the time and, as far as I can tell, never happens under windows.
Has anyone else experienced this problem and does anyone have a fix?
Geoff
Re: Connections in Liinux [message #92951 is a reply to message #92923] Mon, 08 September 2003 10:26 Go to previous messageGo to next message
It sounds like a potential bug in one of the connection anchors. Which
anchor types are you using?
"Geoff Gibbs" <gg@decisionsoft.co.uk> wrote in message
news:bjhjo0$vf0$1@eclipse.org...
windows.
> Geoff
Re: Connections in Liinux [message #93012 is a reply to message #92951] Tue, 09 September 2003 16:05 Go to previous message
I've managed to fix the problem now.
I'm using my own connection anchor that subclasses AbstractConnectionAnchor.
Originally I was doing this:
public Point getLocation(Point reference) {
Rectangle r = Rectangle.SINGLETON;
r.setBounds(getOwner().getBounds());
Point p = r.getLocation();
p.x += r.width / 2;
return p;
But I had a look at the ChopBoxAnchor implementation and changed it to this:
r.translate(-1, -1);
r.resize(1, 1);
getOwner().translateToAbsolute(r);
p.x += r.width / 2;
return p;
This works, but I'm not sure why. Shouldn't the original have the same effect?
> windows.
>>Geoff
Geoff
Previous Topic:Opening a GEF (or SWT) design pallet?
Next Topic:show gridlines in logic example ?
Current Time: Tue Nov 04 15:54:57 EST 2025
Powered by FUDForum. Page generated in 0.13058 seconds
