Home » Archived » Buckminster » Cannot execute Junit Plug-in tests anymore
Cannot execute Junit Plug-in tests anymore [message #929047] Mon, 01 October 2012 03:02 Go to next message
suddenly I cannot seem to execute Junit Plug-in tests with Buckminster
and Jenkins anymore... the jobs that used to work now fail executing
such tests... in the log I see these exceptions (see below)
any clue please?
thanks in advance
Lorenzo
!SESSION 2012-09-30 03:47:30.955
eclipse.buildId=unknown
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -version 3 -port 57712 -testLoaderClass
org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader
-loaderpluginname org.eclipse.jdt.junit4.runtime -classNames
it.xsemantics.example.lambda.tests.ui.LambdaAllUiTests -application
org.eclipse.pde.junit.runtime.uitestapplication -product
org.eclipse.sdk.ide -testpluginname it.xsemantics.example.lambda.tests
Command-line arguments: -os linux -ws gtk -arch x86 -consoleLog
org.eclipse.sdk.ide -data
/usr/share/tomcat6/.jenkins/workspace/Xsemantics-Nightly/../junit-workspace
-dev
file:/usr/share/tomcat6/.jenkins/workspace/Xsemantics-Nightly/.metadata/.plugins/org.eclipse.pde.core/pde-junit/dev.properties
-os linux -ws gtk -arch x86 -consoleLog -testpluginname
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2012-09-30 03:47:32.703
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of
bundle org.eclipse.equinox.simpleconfigurator.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: The System Bundle was
updated. The framework must be restarted to finalize the configuration
change
at
org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:71)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:129)
at
org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:143)
at
org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:48)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Root exception:
java.lang.IllegalStateException: The System Bundle was updated. The
framework must be restarted to finalize the configuration change
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2012-09-30 03:47:32.710
!MESSAGE Bundle
org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744 [1] is not
active.
!ENTRY org.eclipse.osgi 4 0 2012-09-30 03:47:32.722
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Cannot execute Junit Plug-in tests anymore [message #929066 is a reply to message #929047] Mon, 01 October 2012 03:30 Go to previous messageGo to next message
Hi Lorenzo,
maybe this bug report helps:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326682
Dennis.
Re: Cannot execute Junit Plug-in tests anymore [message #929825 is a reply to message #929066] Mon, 01 October 2012 16:15 Go to previous message
On 10/01/2012 09:30 AM, Dennis Hübner wrote:
> Hi Lorenzo,
I don't know whether that's related... I don't have an .eclipse folder
in jenkins...
apparently the problem went away by turning those Junit Plug-in Launch
configurations to be based on features... but I really don't understand
what changed that made this problem show up: nothing had changed in my
code nor in the job configurations...
cheers
Lorenzo
Previous Topic:Rebuilding plugin
Next Topic:svn-git and buckminster - can I pull this off somehow?
Current Time: Sun Jul 27 14:28:42 EDT 2025
Powered by FUDForum. Page generated in 0.35910 seconds
