Home » Eclipse Projects » Remote Application Platform (RAP) » Popup menu doesn't work on ToolBar in CTabFolder top-right
Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92547] Tue, 10 June 2008 10:59 Go to next message
--------------060209060902080300010005
Hi all,
I've created a ToolBar with only one ToolItem of type SWT.DROP_DOWN,
then I've set the ToolBar as the top-right component of a CTabFolder
using setTopRight(...).
In the widgetSelected event of the ToolItem I show a modal popup menu.
When I click on the drop down arrow of ToolItem, the browser (both IE7
and Firefox2.0) dumps a javascript error.
It's a bug or there's another method to show popup menu from ToolItem?
I attach the code snippet and the output from IE7 and Firefox2.0
Enrico
Content-Type: application/octet-stream;
name="CTabFolder_setTopRight_ToolBar.zip"
filename="CTabFolder_setTopRight_ToolBar.zip"
UEsDBBQAAAAIANODyjhdIC71aAIAAGQHAAAQAAAAY29kZV9zbmlwcGV0LnR4 dJ1V32/aMBB+
r9T/4dqHymhVxHiYJk1Io6NoSIwgyIa0l8ngAyw5dhQbKNr6v8+OQ35As9Ge ULAvd9/n+3yx
wVqyXQi+BC4NLFOkBr8PSQt+X19BbisuqYA+14mgB2DQBYn745y0PpWRsw0K AdpH+Blh1QAd
aDQPaiuZJu17sL+Pbfv40G6fRY3oQW0NcUADLkQ+bVXjytGXiC4GSjBMwaxy +tJH9D3M5lEQ
hROfXiYNDcZg+HufU7iIWfmUcTh+rOS4ULe4CJ8MuQ0l3jYAdi4H7JSA0V7V AE/3IFJKPFBX
o1nkBPNB7iwYvobT4c9wHPVG8CdzDEa9qEa5yhhVMuXrjSEO7H+kvqqVrb6g PbqzfM/cn4aT
X/1wPq6z1TRzabUaTyMpYzMUuDRcyRHXBqXdQEdZeHuMJsY68yYt7XO4wzTl DEt3pcF3ijPY
c7ZG46GQkQLzcYe2/9FDnhhfEcCAoaFcQLebldqbTsM55OHn9g3lFmKvVTbJ VW6OzhSOj/oW
LhKfts25xVV9BzzV5vYCps6bmCrNOsOlkqyR6mXv1MpN5VogpHYE3XzT18Wp 0AQ3Ue6ASoxf
tZ8ShxE83UP2f4B3frBB19dNQEmNdUJTtECtwKjjgZaY15UUZ6eVWlLXRzbb Lcg+DxalOf4H
13whkJh0i6+j22+4VY/cxAHXbslKI7Ofwt2dBV6XwK16b561tEVggT3uWU8y B0PNcmOTbMo/
jAVaICaNm/R8fdVUM/NL9annaQ3T52p49YIQ/jqo3xoqQXl0lVoRuNF1rTJp Tr/wl+QAq8cl
GlRWnKLZphLa9m3+5i9QSwMEFAAAAAgAXIPKOGS3j6PiAAAAkwEAABMAAABm aXJlZm94Ml9v
dXRwdXQudHh0dZCxTgNBDET7SPmHVUQRmpUQoQmiQhFQUIBA1OZuuCza292z vXfw9ziQ6hTa
8fiNPbe5xtalrA4jxUoK90kjScOhqGNIyUmwXS6Wi5fvgh1z5q07g9uT2Jor nAtYA+Rgydx5
NDEUgZdJ/W5E0lcN0UuVgtT+CveU2hhStz6/HoktZHA3br76jKFC1HfQhyRK qYH5zesFehza
8UnBa7farNwfbOpPsN5Ca5hHStSBZ8Sp922wLwWGmS6uDDTXNie0y4M2fPka fJMZxwj/Eavs
72J+p/hUYTdawv+lWL21x7yTH1BLAwQUAAAACAChg8o4B1V9mOUAAACXAQAA DgAAAGllN19v
dXRwdXQudHh0dZAxT8QwDIX3Sv0P1i13LJEQxwJiQggYGEBCzKExISh12thu +cn8DFy4qbqb
orw8f895t0VzACoCOPmsXhC+/OS5q2kQqMhDIcartmmbLWnOW/iB5SxQbIrs pgQlRhQpi6nU
6LDLaWB0PIu7m5DkVVJ2rDwghT/hwVPIieLu7Hry1WJGuIH16AuOiizO2I/E 4qlD85vXMcrh
0dYnwbqDzX4D/7C5P8J6S8EwT558xLoizr0Lyf7JaJj5/NJAa21/RLtYtPHb aXJdqXiIcB9Z
+fM+l3efnxVtR0s4XYoVrD2uO2mbX1BLAQIUABQAAAAIANODyjhdIC71aAIA AGQHAAAQAAAA
AAAAAAAAIAAAAAAAAABjb2RlX3NuaXBwZXQudHh0UEsBAhQAFAAAAAgAXIPK OGS3j6PiAAAA
kwEAABMAAAAAAAAAAAAgAAAAlgIAAGZpcmVmb3gyX291dHB1dC50eHRQSwEC FAAUAAAACACh
g8o4B1V9mOUAAACXAQAADgAAAAAAAAAAACAAAACpAwAAaWU3X291dHB1dC50 eHRQSwUGAAAA
AAMAAwC7AAAAugQAAAAA
--------------060209060902080300010005--
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92605 is a reply to message #92547] Tue, 10 June 2008 17:06 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Enrico,
thanks for the hint. We will look into this and post the results here.
Rüdiger
Enrico Zanaga wrote:
> Hi all,
> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92873 is a reply to message #92547] Wed, 11 June 2008 11:31 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Enrico,
first of all I can't find these too classes WFToolBar/WFToolItem, that's
why I reworked your snippet based on ToolBar/ToolItem (see the snippet
bellow). Hope that it's working for you.
final ToolBar tftb = new ToolBar(tf, SWT.HORIZONTAL | SWT.FLAT);
tf.setTopRight(tftb);
final ToolItem tfti1 = new ToolItem(tftb, SWT.DROP_DOWN);
tfti1.setText("Tool");
tfti1.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
if( e.detail == SWT.ARROW ) {
Menu m = new Menu( tftb.getShell(), SWT.POP_UP );
MenuItem mi1 = new MenuItem(m, SWT.NONE);
mi1.setText("First");
MenuItem mi2 = new MenuItem(m, SWT.NONE);
mi2.setText("Second");
Point point = new Point( e.x, e.y );
m.setLocation( point );
m.setVisible( true );
Best,
Ivan
> Hi all,
> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92887 is a reply to message #92873] Wed, 11 June 2008 11:54 Go to previous messageGo to next message
Hi Ivan,
sorry, it's my mistake.
However the reworked code doesn't work for me, but it's working for you?
If yes, can you tell me what version (RAP, Eclipse) are you using, please?
I try the code in 1.1M3 and 1.1RC3 without success...
Enrico
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> @Override
> Best,
> Ivan
>> Hi all,
>> Thanks,
>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92901 is a reply to message #92887] Wed, 11 June 2008 12:19 Go to previous messageGo to next message
Hi Enrico,
I run it against 1.1RC3 in FF 2.0.0.14, IE7 and Safari 3.1.1 on Windows
XP SP3.
What kind of problems do you have - JavaScript error? Did you use the
exact snippet from my previous post?
Best,
Ivan
> Hi Ivan,
> please?
> Enrico
>> Hi Enrico,
>> that's why I reworked your snippet based on ToolBar/ToolItem (see the
>> snippet bellow). Hope that it's working for you.
>> @Override
>> Best,
>> Ivan
>>> Hi all,
>>> IE7 and Firefox2.0) dumps a javascript error.
>>> Thanks,
>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #92916 is a reply to message #92901] Wed, 11 June 2008 12:57 Go to previous messageGo to next message
Hi Ivan,
running your snippet in IE7, I get the following javascript error:
Could not evaluate javascript response:
'null' è nullo o non è un oggetto
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "3" );var
wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose( "w15"
);wm.dispose( "w14" );wm.dispose( "w13"
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();
Maybe a qooxdoo problem?
In Jetty/Eclipse console nothing happen...
Enrico
> Hi Enrico,
> XP SP3.
> Best,
> Ivan
>> Hi Ivan,
>> please?
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> @Override
>>> Best,
>>> Ivan
>>>> Hi all,
>>>> Thanks,
>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93004 is a reply to message #92916] Thu, 12 June 2008 03:07 Go to previous messageGo to next message
Hi Enrico,
please attach your complete file to have a look at it.
Ivan
> Hi Ivan,
> Enrico
>> Hi Enrico,
>> Windows XP SP3.
>> Best,
>> Ivan
>>> Hi Ivan,
>>> you?
>>> please?
>>> Thanks,
>>> Enrico
>>>> Hi Enrico,
>>>> the snippet bellow). Hope that it's working for you.
>>>> @Override
>>>> Best,
>>>> Ivan
>>>>> Hi all,
>>>>> menu.
>>>>> ToolItem?
>>>>> Thanks,
>>>>> Enrico
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93030 is a reply to message #93004] Thu, 12 June 2008 03:41 Go to previous messageGo to next message
--------------040307050003010209030100
Hi Ivan,
I've attached the class I use to reproduce the problem.
Enrico
> Hi Enrico,
> Ivan
>> Hi Ivan,
>> 'null'
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93045 is a reply to message #93030] Thu, 12 June 2008 05:01 Go to previous messageGo to next message
--------------040501060704080007080705
Hi Enrico,
here is the reworked complete code... please test it. You don't need
this in widgetSelected:
while (!m.isDisposed() && m.getVisible()) {
if (!d.readAndDispatch())
d.sleep();
m.dispose();
Hope this will help.
Best,
Ivan
> Hi Ivan,
> Enrico
>> Hi Enrico,
>> Thanks,
>> Ivan
>>> Hi Ivan,
>>> 'null'
Re: Popup menu doesn't work on ToolBar in CTabFolder top-right [message #93105 is a reply to message #93045] Thu, 12 June 2008 08:19 Go to previous message
Hi Ivan,
it works! Many thanks!
The code in widgetSelected comes from an old version of SWT, and it
continues to work in SWT 3.3 e 3.4 (RCP mode).
Because my application runs both in RCP and RAP the sources are shared,
except a little compatibility library.
I tested the code in both two modes and it works, so this is the final
solution.
Enrico
> Hi Enrico,
> d.sleep();
> m.dispose();
> Best,
> Ivan
>> Hi Ivan,
>> Thanks,
>> Enrico
>>> Hi Enrico,
>>> Thanks,
>>> Ivan
>>>> Hi Ivan,
>>>> );var wm = org.eclipse.swt.WidgetManager.getInstance();wm.dispose(
>>>> "w15" );wm.dispose( "w14" );wm.dispose( "w13"
>>>> Thanks,
>>>> Enrico
>>>>> Hi Enrico,
>>>>> Windows XP SP3.
>>>>> the exact snippet from my previous post?
>>>>> Best,
>>>>> Ivan
>>>>>> Hi Ivan,
>>>>>> for you?
>>>>>> please?
>>>>>> Thanks,
>>>>>> Enrico
>>>>>>> Hi Enrico,
>>>>>>> @Override
>>>>>>> Best,
>>>>>>> Ivan
>>>>>>>> Hi all,
>>>>>>>> SWT.DROP_DOWN,
>>>>>>>> CTabFolder
>>>>>>>> menu.
>>>>>>>> (both IE7 and Firefox2.0) dumps a javascript error.
>>>>>>>> ToolItem?
>>>>>>>> Thanks,
>>>>>>>> Enrico
Previous Topic:RAP Startup Page
Next Topic:Aligment in tree
Current Time: Fri Oct 31 19:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.09064 seconds
