Home » Archived » BIRT » Cascading parameters
Cascading parameters [message #92746] Fri, 18 November 2005 13:15 Go to next message
Hi All;
Can anyoine point me to some docs and/or samples for making cascading
parameters work? I'm using BIRT 2.0 M2 and can see UI features in the
designer, but they are not working as I would expect and I don;t know if
it's because I'm using them wrong or if the functionality isn't complete
in the M2 release.
The steps I've taken are roughly:
* Right click on report parms and select "New Cascading Parameter"
* I can create the nested parameters, but expected the value from the
first query to be used as the input value to the 2nd parameter's data set
query.
* The designer UI seems to overwrite the data set source for the first
paramter with the one I specify for the second.
* Does this mean that both parameters must use the same data set source?
Any help appreciated.
Pete H
Re: Cascading parameters [message #92764 is a reply to message #92746] Fri, 18 November 2005 13:21 Go to previous messageGo to next message
Pete,
The current functionallity requires that the Cascaded parameter set come
from the same Data Set.
Jason Weathersby
BIRT PMC
"Pete H" <phazzard@llbean.com> wrote in message
news:3c925b9a3b3ecc55dd472d06762f8894$1@www.eclipse.org...
> Hi All;
> in the M2 release.
> query. * The designer UI seems to overwrite the data set source for the
> first paramter with the one I specify for the second.
> Pete H
Re: Cascading parameters [message #92778 is a reply to message #92764] Fri, 18 November 2005 13:45 Go to previous messageGo to next message
Jason Weathersby wrote:
> Pete,
> Jason Weathersby
> BIRT PMC
Ouch - I was afraid you might say that... Is this recognized as a serious
limitation? In our case, it means that some of the parameter control data
sets will be too large and it may not give us the function we need.
Bugzilla? Thanks for the quick response - it gives me something to work
with.
Pete H
Re: Cascading parameters [message #92823 is a reply to message #92778] Fri, 18 November 2005 14:50 Go to previous messageGo to next message
Pete,
I didnt mean to cause pain :>
I dont know if something is logged in Bugzilla yet.
If not go ahead. As work around, can you use a driver report with
Hyperlinks?
Jason
news:ad8bf4651a91bf6050744842a7c2362a$1@www.eclipse.org...
>> Pete,
>> Jason Weathersby
>> BIRT PMC
> with.
> Pete H
Re: Cascading parameters [message #92910 is a reply to message #92778] Fri, 18 November 2005 16:01 Go to previous messageGo to next message
Pete,
Please add your comments and use cases to the bugzilla entry
https://bugs.eclipse.org/bugs/show_bug.cgi?id=116960
--Thanks
Rima Kanguri.
> > Pete,
> > Jason Weathersby
> > BIRT PMC
> with.
> Pete H
Re: Cascading parameters [message #92940 is a reply to message #92778] Fri, 18 November 2005 17:17 Go to previous message
I've allready posted to bugzilla. See bug number 116956.
Previous Topic:Display problems of data with carriage return / line feeds
Next Topic:dynamic images
Current Time: Sun Nov 09 04:43:32 EST 2025
Powered by FUDForum. Page generated in 0.05527 seconds
