| Upgrade strategies [message #92325] | Fri, 11 July 2003 21:50  |  |
| Eclipse User  |  |  |  |  | Greetings -
 I wanted to share my only significant frustration with Eclipse after a
 year and half of using it with the group. That is, upgrades.  They are a
 pain.  The usual routine I find myself doing is:
 (1) Download the latest release, unzip it, and drop it in a shared
 directory for all my eclipse versions.  Looks like this:
 +-usr/
 +-local/
 +-eclipse/
 +-eclipse
 +-eclipse-2.0
 +-eclipse-2.1
 +-eclipse-2.1.1
 +-eclipse-3.0-M1
 +-current -> eclipse-2.1.1
 +-features -> current/features
 +-plugins -> current/plugins
 +-workspace
 where /usr/local/eclipse/eclipse is a shell script:
 (cd /usr/local/eclipse/current; \
 ./eclipse -data /usr/local/eclipse/workspace &)
 (2) Back-up workspace
 (3) Copy plugins that I custom installed from current/plugins to the new
 version's plugin directory; repeat with features
 (4) rm current; ln -s eclipse-3.0-M1 current
 (5) run ./eclipse and pray to god that nothing broke
 Many times I have had to blow away workspace/.metadata and reconstruct
 projects; sometimes have had to blow away even the .project files in
 each module.  Many times the plugins fail so I will have to retrieve
 more recent versions.  At least it forces me to keep current.
 Things are getting worse now that I have multiple workspace directories
 here and there.
 Is anyone else manageing to make this process easier?  Am I missing some
 crucial thing that would simplify my life 100 times.  Are there any
 plans to apply the Update Manager to the core and plugins of Eclipse
 itself ("Physician, heal thy self" vs "The shoemaker's children"
 syndrome).  I for one would love to see the latter.  Netbeans at least
 had it (did not always work, but hey! you take what you can get).
 Jeffrey Bonevich
 Ann Arbor, Michigan
 bonevich at covad dot net
 jeff at bonevich dot com
 http://www.bonevich.com
 "Make me a fire and I'm warm for a night.  Set me
 on fire and I'm warm for the rest of my life."
 - Ancient Didactical Saying
| Re: Upgrade strategies [message #92854 is a reply to message #92325] | Mon, 14 July 2003 04:14  |  |
| Eclipse User  |  |  |  |  | Originally posted by: daniel.megert.gmx.net
 Jeffrey Bonevich wrote:
 > Greetings -
 > a pain.
 I filed a feature request for Update Manager to allow time
 stamp/non-version based updates a while ago:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=29776
 This could ease updating a lot but it was closed as wontfix. I added
 some comments below which might help to improve your update process a bit.
 >   +-usr/
 >     +-local/
 >       +-eclipse/
 >         +-eclipse
 >         +-eclipse-2.0
 >         +-eclipse-2.1
 >         +-eclipse-2.1.1
 >         +-eclipse-3.0-M1
 >         +-workspace
 > new version's plugin directory; repeat with features
 1. Put all your custom plug-ins at one location outside the Eclipse
 install tree (e.g. C:/eclipse/customPlugins) and keep them there.
 2. Create a file called .link with the following content:
 path=C:/eclipse/customPlugins
 3. Create a batch file that starts eclipse but before starting, creates
 a folder called "links" into the eclipse root directory and then copies
 above .link file into "links" folder
 NOTE: Plug-ins which you put into C:/eclipse/customPlugins must be in
 eclipse/plugins, e.g.:
 C:/eclipse/customPlugins/eclipse/plugins/<myCustomPlugin1>
 Well you could leave that step away since you might want to go back to
 that version and disk space is cheap anyway ;-)
 Well I'm developing on the newest builds every week and I think the only
 time when I threw my workspace away was because I decided to do so (to
 get to a clean and fresh state).
 There's now also a workspace restorer plug-in that should help you in
 such situations.
 HTH
 Dani
FUDForum. Page generated in 0.04344 seconds
