Home » Archived » BIRT » Changing the Parameter UI(not sure which extension points tou )
Changing the Parameter UI [message #925443] Thu, 27 September 2012 14:19 Go to next message
For the ODA designer plugin that I am making, I need the UI for creating a new input parameter to have additional options. My plan is for the UI window to create a new Object using values the user types in the text fields, let the ODA driver pass that Object into my IQuery's setObject method, and do additional processing there. What classes should I extend to accomplish this?
Re: Changing the Parameter UI [message #926554 is a reply to message #925443] Fri, 28 September 2012 15:22 Go to previous message
Can you give some more detail on this?
" creating a new input parameter to have additional options."
Jason
Previous Topic:Birt script editor will not load
Next Topic:yet another pdf page break question
Current Time: Sat Jul 26 09:01:52 EDT 2025
Powered by FUDForum. Page generated in 0.07877 seconds
