Home » Eclipse Projects » Eclipse Platform » Re: Adding menu items to File --> New
Re: Adding menu items to File --> New [message #92633] Sat, 12 July 2003 15:59 Go to next message
Originally posted by: cecconae.ig.com.br
Firasat wrote:
> Simon Arsenault wrote:
> > See org.eclipse.ui.IPageLayout.addNewWizardShortcut method
> > Simon :-)
> > "Firasat" <fhussain@cysive.com> wrote in message
> > news:befd44$k9t$1@eclipse.org...
> > > I have created my own perspective with one view and editor. Currently
> > > when I select the File --> New menu, 'Project' and 'Other' items are
> > > displayed.
> > > How do I add my own menu items to the 'New' submenu. I have tried using
> > > actionSet extensions in plugin.xml without success. The best I was able
> > > to do was add the action directly to File menu. What is the correct menu
> > > bar path?
> > > In addition, is there a way to programatically add an action to the File
> > > --> New menu? How would one use org.eclipse.ui.actions.NewWizardMenu?
> > > Thanks.
> I have done what you said, however, I still have to go to Window -->
> Customize Perspective to activate it so it can be shown in File --> New.
> What am I doing wrong? Please site an example using the JDT perspective
> with class names.
> Thanks.
Hi Firasat :
Hope that help you.
To add a wizard in the File --> New menu programatically
public class WebPerspectiveFactory implements IPerspectiveFactory
public void createInitialLayout(IPageLayout pageLayout)
createActions(pageLayout);
public void createActions( IPageLayout pageLayout )
pageLayout.addNewWizardShortcut( "Your Wizard ID");
To add a wizard in the File --> New menu declarative way in plugin.xml
<!-- Purpose: Define perspective extension -->
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="%your.perspective.id">
<perspectiveShortcut id="%your.perspective.id"/>
</perspectiveExtension>
<newWizardShortcut id="your.wizard.id"/>
</extension>
Antonio Edson Ceccon
Re: Adding menu items to File --> New [message #93460 is a reply to message #92633] Mon, 14 July 2003 16:16 Go to previous message
Originally posted by: fhussain.cysive.com
> > > Simon :-)
> > > > displayed.
using
able
menu
> > > > bar path?
File
> > > > Thanks.
> > with class names.
> > Thanks.
> Hi Firasat :
> Hope that help you.
> <extension
> </extension>
> Regards,
Antonio,
Thanks for the help. Adding the extension to the plugin.xml worked.
--Firasat
Previous Topic:Re: JVM crashes during debug
Next Topic:PDE: how to get workspace root for imported project?
Current Time: Fri Jul 18 02:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.12784 seconds
