Home » Archived » Visual Editor (VE) » Visual Editor update site
Visual Editor update site [message #92341] Sun, 29 May 2005 20:38 Go to next message
Originally posted by: weconsul.ptd.net
I am running Eclipse 3.1M7 and installed all of the required libraries
for VE. For VE I installed..
VE-Automated-Tests-1.0.2.1.zip
VE-examples-1.0.2.1.zip
VE-runtime-1.0.2.1.zip
VE-SDK-1.0.2.1.zip
When I look at all of the VE plugins I see the following..
Visual Editor 1.0.1
Visual Editor Common Data Editor 1.0.2
Visual Editor Examples 1.0.1
Visual Editor Examples Source 1.0.1
Visual Editor for Java Foundation Classes 1.0.2
Visual Editor for Standard Widget Toolkit 1.0.2
Visual Editor Java Core 1.0.2.1
Visual Editor PropertySheet 1.0.1
Visual Editor SDK 1.0.1
Visual Editor Editor Source 1.0.2.1
Visual Editor User Guide 1.0.1
The I question I have is every time I check for updates to VE it keeps
installing and reinstalling the following update..
VE
Visual Editor SDK 1.0.2.1
It is like the update is not being registered to a point that it does
not now the update was already applied. Each and every time.
Can anyone give some advice. It s not major problem but seems not to be
installing as designed.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Visual Editor update site [message #92356 is a reply to message #92341] Sun, 29 May 2005 23:13 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
IchBin,
VE 1.0.2 is not compatible with Eclipse 3.1M7. Please try the latest
integration build of the VE, which works on M7. Eclipse 3.1 M7 is still
prerelease software, so the update manager reflects the versions of VE
an other components compatible with the previous version of Eclipse (3.0.2).
Hope this helps,
- Jeff
IchBin wrote:
> Hello,
> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #92416 is a reply to message #92356] Tue, 31 May 2005 02:10 Go to previous messageGo to next message
Thanks Jeff for your reply..
I installed the integration build of VE. Now the update works but now
when I tested the VE by creating a visual class I get the errors below.
It does create the new code for the class but if I select it into the
editor I get the same errors. Can't seem to load the visual editor for
the class.
!ENTRY org.eclipse.core.runtime 4 2 2005-05-31 02:05:00.991
!MESSAGE An internal error occurred during: "Setup Java Visual Editor".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/util/EcoreEList$UnmodifiableEList$Fast Compare
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoAdapterFa ctory.createAdapter(BeaninfoAdapterFactory.java:65)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:112)
at
org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
at
org.eclipse.jem.java.impl.JavaClassImpl.getIntrospectionAdap ter(JavaClassImpl.java:476)
at
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:385)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(ClassDecoratorSourceIterator.java:37)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDecoratorSourceIterator.java:33)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:67)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:82)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:498)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:407)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:851)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:931)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:573)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1779)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
Jeff Myers wrote:
> IchBin,
> (3.0.2).
> Hope this helps,
> - Jeff
> IchBin wrote:
>> Hello,
>> VE-SDK-1.0.2.1.zip
>> be installing as designed.
Re: Visual Editor update site [message #92431 is a reply to message #92416] Tue, 31 May 2005 07:22 Go to previous messageGo to next message
IchBin,
Did you upgrade your versions of EMF and GEF to correspond to the
versions required by that integration build?
- Jeff
> the class.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Jeff Myers wrote:
>> IchBin,
>> still prerelease software, so the update manager reflects the versions
>> of VE an other components compatible with the previous version of
>> Eclipse (3.0.2).
>> Hope this helps,
>> - Jeff
>> IchBin wrote:
>>> Hello,
>>> libraries for VE. For VE I installed..
>>> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #92534 is a reply to message #92431] Tue, 31 May 2005 12:35 Go to previous messageGo to next message
I did download and install the following..
emf-sdo-runtime-I200505261142.zip
emf-sdo-xsd-Automated-Tests-I200505261142.zip
emf-sdo-xsd-Examples-I200505261142.zip
emf-sdo-xsd-SDK-I200505261142.zip
GEF-ALL-3.1M7.zip
GEF-Automated-Tests-3.1M7.zip
GEF-examples-3.1M7.zip
GEF-runtime-3.1M7.zip
GEF-SDK-3.1M7.zip
JEM-runtime-I20050526.zip
JEM-SDK-I20050526.zip
VE-Automated-Tests-I20050526.zip
VE-examples-I20050526.zip
VE-runtime-I20050526.zip
VE-SDK-I20050526.zip
xsd-runtime-I200505261142.zip
When I look at the features in the about dialog I see the following
All EMF's are at 2.1.0.200505050300
All GEF's are at 3.1.0
Feature Visual Editor 1.0.1
Plug-in Visual Editor 1.0.1
Plug-in Visual Editor Common Data Editor 11.0.0
Plug-in Visual Editor For Java Foundation Classes 1.1.0
Plug-in Visual Editor For Standard Widget Toolkit 1.1.0
Plug-in Visual Editor Java Core 1.1.0
Plug-in Visual Editor ProperitySheet 1.0.1
Plug-in Visual Editor User Guide 1.0.1
Jeff Myers wrote:
> IchBin,
> - Jeff
>> below. It does create the new code for the class but if I select it
>> into the editor I get the same errors. Can't seem to load the visual
>> editor for the class.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Jeff Myers wrote:
>>> IchBin,
>>> versions of VE an other components compatible with the previous
>>> Hope this helps,
>>> - Jeff
>>> IchBin wrote:
>>>> Hello,
>>>> VE-SDK-1.0.2.1.zip
>>>> does not now the update was already applied. Each and every time.
Re: Visual Editor update site [message #92578 is a reply to message #92534] Tue, 31 May 2005 13:54 Go to previous messageGo to next message
You can't use VE 1.0.1 with Eclipse M7. It only works with Eclipse
3.0.x. However, you said you download VE I2--5-526, but you only 1.0.1
installed. That means things are not installing correctly. Try a brand
new installation of JUST and nothing else:
Eclipse SDK 3.1M7, GEF runtime 3.1M7, emf-sdo-runtime I200505261142, and
VE runtime I20050256.
You probably tried installing over the old installations and just got
Eclipse confused.
You don't need any of the other stuff, in fact you have some downloaded
more than once (VE SDK includes the VE runtime, GEF SDK includes the GEF
runtime, emf-sdo-xsd-SDK includes the emf-sdo-runtime). You don't need
the tests at all. Those are only for re-running the tests that we run in
the build, you don't need that.
> GEF-ALL-3.1M7.zip
> GEF-SDK-3.1M7.zip
Rich Kulp
Re: Visual Editor update site [message #92653 is a reply to message #92534] Tue, 31 May 2005 14:31 Go to previous messageGo to next message
Did you apply the -clean on the command line argument to force eclipse to reRead the plugins manifest?
Re: Visual Editor update site [message #92814 is a reply to message #92653] Thu, 02 June 2005 16:39 Go to previous messageGo to next message
Thanks Gili,
I use to make that mistake. I always do it now when anything gets
installed..
Re: Visual Editor update site [message #92829 is a reply to message #92578] Thu, 02 June 2005 16:40 Go to previous messageGo to next message
Thanks Rich,
That did work after starting fresh with the following..
eclipse-SDK-3.1M7-win32.zip
GEF runtime 3.1M7
I then did an Search for Updates to apply any newer updates. It said to
select the features to install..
EMF/SDO/XSD Secondary Update Site
EMF SDK 2.1.0 I200503310700
EMF SDK 2.1.0 I200504070700
EMF SDK 2.1.0 I200504141117
EMF SDK 2.1.0 I200504210500
EMF SDK 2.1.0 I200504280300
EMF SDK 2.1.0 I200505050300
So I installed these and this is when the problem started again.
Guess I do not know what to update.. I thought that Eclipse would know
what I had installed and was tell me that I needed to apply these updates.
Now I200505050300 is showing for EMF and SDO in the Product configuration.
So basically for any plugin for Eclipse I only need to apply the SDK..
I really do not need to install the runtime or any other downloads.
Sorry I am confused with all of the variations of a downloads per plug-in..
Say base stuff
*eclipse-examples-3.1M7-win32.zip*
*eclipse-FTP-WebDAV-3.1M7.zip*
eclipse-JDT-3.1M7.zip
eclipse-JDT-SDK-3.1M7.zip
eclipse-PDE-3.1M7.zip
eclipse-PDE-SDK-3.1M7.zip
eclipse-platform-3.1M7-win32.zip
eclipse-platform-SDK-3.1M7-win32.zip
eclipse-RCP-3.1M7-win32.zip
*eclipse-RCP-SDK-3.1M7-win32.zip*
eclipse-test-framework-3.1M7.zip
*org.eclipse.releng.tools_3.1.0.zip*
*swt-3.1M7-win32-win32-x86.zip*
The extra plugins I use..
*emf-sdo-xsd-Examples-I200505261142.zip*
GEF-ALL-3.1M7.zip
*GEF-runtime-3.1M7.zip*
GEF-SDK-3.1M7.zip
*JEM-SDK-I20050526.zip*
*org.eclipse.cdt.sdk-2.1.0-win32.x86.zip*
*org.eclipse.cdt-2.1.0-win32.x86.zip*
uml2-automated-tests-1.0.0.zip
*uml2-examples-1.0.0.zip*
*uml2-SDK-1.0.0.zip*
*VE-runtime-I20050526.zip*
*wtp-1.0M4.zip*
wtp-jst-Automated-Tests-1.0M4.zip
wtp-jst-perf-Tests-1.0M4.zip
*wtp-sdk-1.0M4.zip*
*wtp-wst-1.0M4.zip*
wtp-wst-Automated-Tests-1.0M4.zip
wtp-wst-perf-Tests-1.0M4.zip
wtp-wst-sdk-1.0M4.zip
*xsd-runtime-I200505261142.zip*
> Eclipse confused.
Re: Visual Editor update site [message #92859 is a reply to message #92829] Thu, 02 June 2005 17:05 Go to previous message
Don't install them. They are all the same thing, just different
development drivers. For example I200503310700 says this is the
development driver from March 31, 2005 at 7AM. So I200504070700 is the
April 7, 2005 at 7AM. You should have only the EMF driver that the VE
download page says is compatible with it, or a newer one.
IchBin wrote:
> Thanks Rich,
> GEF runtime 3.1M7
Rich Kulp
Re: Visual Editor update site [message #607844 is a reply to message #92341] Sun, 29 May 2005 23:13 Go to previous message
IchBin,
Hope this helps,
- Jeff
IchBin wrote:
> Hello,
> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #607848 is a reply to message #92356] Tue, 31 May 2005 02:10 Go to previous message
the class.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Jeff Myers wrote:
> IchBin,
> (3.0.2).
> Hope this helps,
> - Jeff
> IchBin wrote:
>> Hello,
>> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #607849 is a reply to message #92416] Tue, 31 May 2005 07:22 Go to previous message
IchBin,
- Jeff
> the class.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Jeff Myers wrote:
>> IchBin,
>> Eclipse (3.0.2).
>> Hope this helps,
>> - Jeff
>> IchBin wrote:
>>> Hello,
>>> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #607856 is a reply to message #92431] Tue, 31 May 2005 12:35 Go to previous message
GEF-ALL-3.1M7.zip
GEF-SDK-3.1M7.zip
Jeff Myers wrote:
> IchBin,
> - Jeff
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Jeff Myers wrote:
>>> IchBin,
>>> Hope this helps,
>>> - Jeff
>>> IchBin wrote:
>>>> Hello,
>>>> VE-SDK-1.0.2.1.zip
Re: Visual Editor update site [message #607859 is a reply to message #92534] Tue, 31 May 2005 13:54 Go to previous message
Eclipse confused.
> GEF-ALL-3.1M7.zip
> GEF-SDK-3.1M7.zip
Rich Kulp
Re: Visual Editor update site [message #607864 is a reply to message #92534] Tue, 31 May 2005 14:31 Go to previous message
Re: Visual Editor update site [message #607875 is a reply to message #92653] Thu, 02 June 2005 16:39 Go to previous message
Thanks Gili,
installed..
Re: Visual Editor update site [message #607876 is a reply to message #92578] Thu, 02 June 2005 16:40 Go to previous message
Thanks Rich,
GEF runtime 3.1M7
Say base stuff
GEF-ALL-3.1M7.zip
GEF-SDK-3.1M7.zip
*wtp-1.0M4.zip*
*wtp-sdk-1.0M4.zip*
*wtp-wst-1.0M4.zip*
> Eclipse confused.
Re: Visual Editor update site [message #607878 is a reply to message #92829] Thu, 02 June 2005 17:05 Go to previous message
IchBin wrote:
> Thanks Rich,
> GEF runtime 3.1M7
Rich Kulp
Previous Topic:M2 schedule
Next Topic:New nightly? Customizer is failing.
Current Time: Thu Jul 24 21:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.44714 seconds
