Home » Modeling » EMF » XCore install issues
XCore install issues [message #925507] Thu, 27 September 2012 15:52 Go to next message
Every time I've tried to install XCore, both on Indigo and now Juno, I have the following issue:
If I install XCore first, it works.
If I then install XText/XPand, nothing works -- the editors aren't recognized, etc...
If I uninstall XText/Xpand and then reinstall XCore, everything works again
Nartually, since the Score projects actually require Xtext, this presents a problem.
Also, I'm wondering if XCore is suppossed to implement the XTend Template (''') syntax. I can't get it to work, but I was thining that might be due to the issue above..
thanks!
Miles
Re: XCore install issues [message #925943 is a reply to message #925507] Fri, 28 September 2012 02:49 Go to previous messageGo to next message
Miles,
Comments below.
> recognized, etc...
Xcore requires Xtext...
> again
> presents a problem.
You've tried installing Xtext and Xpand first. I don't see how order
affects anything...
No, that's not an Xbase thing.
> thanks!
> Miles
Re: XCore install issues [message #926427 is a reply to message #925943] Fri, 28 September 2012 12:42 Go to previous messageGo to next message
Thanks Ed.,,
Figured it out. It was actually a problem with my Target Platform, should have seen that earlier. But that brings up a question -- why *does* the xtext dependency have to be in the base project? Isn't this really a build time concern, since all of the code that is emitted has no dependencies on xtext..? Ideally, I'd be able to use xcore projects w/ the same dependencies as plain old ecore gen code.
Really enjoying xcore, to the extent that I keep expecting it to do things it wasn't really designed for.. Smile
cheers,
Miles
Re: XCore install issues [message #926435 is a reply to message #926427] Fri, 28 September 2012 12:49 Go to previous message
Miles,
Comments below.
On 28/09/2012 6:42 PM, Miles Parker wrote:
> Thanks Ed.,,
It's actually an Xbase dependency which is needed if you have any
behavior specified in your model (derived features, operations, or data
conversion).
Other than the generated method bodies, if any.
That's possible in principle, if you don't make use of Xbase in your
Xcore model.
> things it wasn't really designed for.. :)
We'll have to improve the design to exceed expectations.
> cheers,
> Miles
Previous Topic:[CDO] Thread-local legacy mode default
Next Topic:[XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at all
Current Time: Sat Jul 26 12:01:25 EDT 2025
Powered by FUDForum. Page generated in 0.05484 seconds
