Home » Eclipse Projects » Eclipse 4 » How to access to menu item?
How to access to menu item? [message #924793] Thu, 27 September 2012 02:05 Go to next message
To change some properties of menu item programmatically (visible, label, selected etc.) I need to have the instance of this menu item (MHandledMenuItem or MDirectMenuItem).
I tried in the handler:
@Inject
@Named("menuItemId")
MHandledMenuItem menuItem;
- no result,
@Execute
public void execute(EModelService service, MApplication application) {
MUIElement element = service.find("menuItemId", application);
- element is null (tried the window in place of application too),
@Execute
List<MHandledMenuItem> list = service.findElements(application, "menuItemId", MHandledMenuItem.class, null);
- list is empty.
The EMenuServise don't allow this.
What should I do?
I didn't find the answer to this question in internet and accessible tutorials.
Re: How to access to menu item? [message #924826 is a reply to message #924793] Thu, 27 September 2012 02:43 Go to previous messageGo to next message
Wild guess is that the EModelService is not searching through the
Main-Menu structure (which i'd consider a bug!). So you need to traverse
the MApplication-Element your own.
Tom
Am 27.09.12 08:05, schrieb Gennady Gromov:
> @Inject
> - no result,
> @Execute
> @Execute
> - list is empty.
> What should I do?
> tutorials.
Re: How to access to menu item? [message #924888 is a reply to message #924826] Thu, 27 September 2012 04:01 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=383403
Re: How to access to menu item? [message #925011 is a reply to message #924888] Thu, 27 September 2012 06:01 Go to previous messageGo to next message
As I understood from this link, it is impossible now by the EModelService.
May be there is another way to get the instance of menu item?
Re: How to access to menu item? [message #925083 is a reply to message #925011] Thu, 27 September 2012 06:59 Go to previous message
Yes get the MApplication and search you own following its children, .... .
Tom
Am 27.09.12 12:01, schrieb Gennady Gromov:
> EModelService. May be there is another way to get the instance of menu
> item?
Previous Topic:Handler executes on rcp launch
Next Topic:Tycho and OS X code signing
Current Time: Sat Jul 26 17:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
