Home » Eclipse Projects » Eclipse 4 » Handler executes on rcp launch
Handler executes on rcp launch [message #924843] Thu, 27 September 2012 03:05 Go to next message
1. I am building a small rcp application based on pure e4 to learn the new paradigms. I have build an application with Application.e4xmi in one bundle and a fragment.e4xmi in another. The Application.e4xmi has a perspectivestack and the fragment.e4xmi hooks with a perspective into this stack. In the fragment I have a part with a pojo view und added to the part in the menus section some popupmenus. The menuitems are connected with pojo handlers. When I start the app before the main window shows up, every popup menu handler is executed. Do I missing something?
2. In my fragment.e4xmi under the part I do not find a toolbar section (a view toolbar). How do I add a toolbar to a part in *.e4.xmi?
Thank you
Christian
Re: Handler executes on rcp launch [message #924897 is a reply to message #924843] Thu, 27 September 2012 04:10 Go to previous messageGo to next message
Ad 2: is resolved: Just check the checkbox "toolbar" in part section.
Re: Handler executes on rcp launch [message #924907 is a reply to message #924897] Thu, 27 September 2012 04:23 Go to previous messageGo to next message
Hi Christian,
I have a setup that is very similar to yours without the problems you mentioned. When you debug your code (put a break-point in @Execute of a Handler) and go back until you find ContextInjectionFactory.invoke(contrib.getObject(), Execute.class, lclContext) where does this get called?
Greetings
Christoph
Re: Handler executes on rcp launch [message #924911 is a reply to message #924843] Thu, 27 September 2012 04:24 Go to previous messageGo to next message
Ad 1: When I select an entry in the table of the view, any registered handler executes too. What am I doing wrong?
Re: Handler executes on rcp launch [message #924919 is a reply to message #924907] Thu, 27 September 2012 04:32 Go to previous messageGo to next message
Hi Christoph,
There is no ContextInjectionFactory.invoke, there is a Method.invoke and aContextInjectionFactory.make. I attach a screenshot of the debug output.
Thank you!
Re: Handler executes on rcp launch [message #924928 is a reply to message #924919] Thu, 27 September 2012 04:36 Go to previous messageGo to next message
Can you show us your Handler? In handlers you don't use @Inject, I guess
your handler is written wrong and looks like this:
@Execute
@Inject
void handle() {
which is wrong and should look like this:
@Execute
void handle() {
Tom
Am 27.09.12 10:32, schrieb Christian Eugster:
> Hi Christoph,
> Thank you!
Re: Handler executes on rcp launch [message #924935 is a reply to message #924928] Thu, 27 September 2012 04:45 Go to previous messageGo to next message
The call comes from the processHierarchy call which doesn't run the @Execute. I plan to remove the processHierarchy once and for all in https://bugs.eclipse.org/bugs/show_bug.cgi?id=376254
Re: Handler executes on rcp launch [message #924936 is a reply to message #924928] Thu, 27 September 2012 04:48 Go to previous messageGo to next message
You are right, Tom, that was the problem. I removed the @Inject annotation and everything works ok! Thank you!
Re: Handler executes on rcp launch [message #924964 is a reply to message #924935] Thu, 27 September 2012 05:10 Go to previous messageGo to next message
This would not have solved the problem because at a given point we need
to create an instance of the handler and then we would have called the
method annotated with @Inject ;-)
Tom
Am 27.09.12 10:45, schrieb Sopot Cela:
Re: Handler executes on rcp launch [message #924969 is a reply to message #924964] Thu, 27 September 2012 05:20 Go to previous message
I never said the bug solves the problem, I just referenced the bug so that in the future it won't be needed to be called as (as stated in the bug) people are using it already in their POJOs.
And IIRC the processHirerarchy itself (and so will my addon) called the @Inject as part of the call to the ICF.create so Kudos for spotting that Smile
Previous Topic:Removing Some menu items programatically
Next Topic:How to access to menu item?
Current Time: Fri Jul 25 17:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.08677 seconds
