Exchange the InputStream [message #917646] |
Thu, 20 September 2012 05:34  |
I have read about registering an own lexer and more for your language, so I wonder if the following is also possible:
Decrypt a file with a simple encryption algorithm (e.g. Caesar cipher) while reading, and encrypting it again while writing. So far I work on a temporary copy of the decrypted file in the IDE, and write it back encrypted on save.
Is it possible to exchange e.g. the InputStream that Xtext uses with a class that does some kind of manipulation on the bytes read? Which binding in the RuntimeModule would have to be changed?
The benefit would be that the encryption is very transparent.
Thank you very much for every help!
Re: Exchange the InputStream [message #925444 is a reply to message #925379] |
Thu, 27 September 2012 14:18   |
On 2012-27-09 10:05, Moritz Höser wrote:
> Great, I think the EFS is exactly what I was looking for, thank you.
> I wrote a FileStore for this purpose (providing a custom InputStream),
> but I don't know how to register it properly. If I use a new FileSystem,
> it will only be activated when the file uri has a special scheme. I want
> to use the "file:" scheme, so that a simple double click opens an editor
> with the decrypted file, as you suggested.
> In case someone is looking for a solution, I opened
> http://www.eclipse.org/forums/index.php/t/386177/ since this is not
> directly Xtext
> Henrik Lindberg wrote on Thu, 27 September 2012 01:19
>> Sounds like you want to cut into the process where an IResource is
>> being read. I wonder if it would perhaps best be implemented as an
>> Eclipse File System where files can be encrypted. That would make it
>> completely transparent to all upper layers. This way even a simple
>> text editor could open an encrypted file.
Replace the file scheme with a delegating scheme ?
- henrik
Re: Exchange the InputStream [message #925732 is a reply to message #925444] |
Thu, 27 September 2012 21:27   |
I think you suggest to change the files locationUri. This may be possible for single files if done by hand, but to keep track of all the ways a file can be created and change its uri programmatically seems like an awful lot of work to me.. And when the root folder of a file is a linked, non-virtual folder, its not possible to change the file scheme. So if I see it right, when one want to use the standard Project Explorer and so on, a custom FileStore must be provided with the "file" filesystem (aka LocalFileSystem).
To see if it works, I registered a FileSystem to the scheme "file" which provides FileStores that are fully compatible with the usually ones but open special InputStreams for the encrypted file types. This works, Xtext loads the encypted files and displays the decrypted text, and saves the text encrypted again without any other modifications. But it is rather ugly, since having a second "file" FileSystem is not intended.
I will try to work with a special charset / Encoding instead.
If someone has any other ideas or remarks, please let me know.
Henrik Lindberg wrote on Thu, 27 September 2012 14:18Replace the file scheme with a delegating scheme ?
- henrik
Thank you for your help Henrik.
Re: Exchange the InputStream [message #949201 is a reply to message #925732] |
Thu, 18 October 2012 15:59  |
hi Henrik,
probably its too late for your solution. I had the same problem today and found the solution in the Platform Plugin developer guide. You will have to create another extension point like this:
<extension
point="org.eclipse.ui.ide.filesystemSupport">
<filesystemContributor
class="de.braintags.filesystem.NetRelayFileSystemContributor"
label="NetRelay file system (nrfs )"
scheme="nrfs">
</filesystemContributor>
</extension>
where the class is extending org.eclipse.ui.ide.fileSystem.FileSystemContributor
After you did that, start your plugin and call File -> New -> File. Then you open the advanced part, activate "link to file into the file system", open the select box at "Choose file system" and you will be able to choose your filesystem definition - in my case there is now displayed "NetRelay file system ( nrfs)"
regards,
Mike
FUDForum. Page generated in 0.24718 seconds
