Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] XMI Serialization in/from multiple files
[Texo] XMI Serialization in/from multiple files [message #923921] Wed, 26 September 2012 06:03 Go to next message
Hi Martin,
Currently I can use ModelXMLSaver/ModelXMLLoader to serialize a object graph in/from XML (via setConvertNonContainedReferencedObjects as true).
It works pretty well.
And now I want to save cross-reference objects to their own xml file according to their type.
Imagine I have a ecore meta model with Person, Address and Person has a cross reference to Address.
I want to serialize Persons and Addresses into their own xml file like "Persons.xml", "Addresses.xml" and still keep the cross reference between them so that I can load them back.
I'm familiar with EMF Resource/ResourceSet concept, but it seems a little bit different in the context of Texo.
Do you have any suggestion to achieve this goal in Texo?
Best wishes,
Oliver
[Updated on: Wed, 26 September 2012 06:04] by Moderator
Re: [Texo] XMI Serialization in/from multiple files [message #923929 is a reply to message #923921] Wed, 26 September 2012 06:09 Go to previous messageGo to next message
Hi Oliver,
I think in this case your best 'bet' is to first convert the Texo pojo's to EMF objects and then you can do what you
want using standard EMF. This is also done internally by the ModelXMLLoader and ModelXMLSaver.
For model to emf and back see this page:
http://wiki.eclipse.org/Texo/Convert_to_EMF
gr. Martin
On 09/26/2012 12:03 PM, Oliver Zhou wrote:
> Hi Martin,
> Imagine I have a ecore meta model with Person, Address.
> Best wishes,
> Oliver
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] XMI Serialization in/from multiple files [message #925980 is a reply to message #923929] Fri, 28 September 2012 03:37 Go to previous message
Hi Martin,
Thanks, it's working well.
The converter is just cool
Previous Topic:Diagram Editor documentation
Next Topic:(later) undo "delete from diagram"
Current Time: Sun Jul 27 18:10:39 EDT 2025
Powered by FUDForum. Page generated in 0.03927 seconds
