Home » Modeling » EMF » [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at all([XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at all)
[XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at all [message #923256] Tue, 25 September 2012 15:05 Go to next message
I created a xcore meta-model that refers to an existing .ecore model. This .ecore model does not have the XText nature. When I put the plugin dependency in the Manifest.MF (XCore Project) then I am unable to open the .xcore and I get the the following Exception:
"java.lang.IllegalStateException: Was configured with another client or not configured at all."
It seems it is related to XText itself. Help would be appreciated.
Thanks Wink
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #923274 is a reply to message #923256] Tue, 25 September 2012 15:28 Go to previous messageGo to next message
Can you provide a stack trace? This is with the EMF 2.8 release?
On 25/09/2012 9:05 PM, Régent L Archevêque wrote:
> Thanks ;)
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #924062 is a reply to message #923274] Wed, 26 September 2012 09:10 Go to previous messageGo to next message
Hi Ed,
yes I am using EMF 2.8.0.v20120608-0554 with Eclipse Juno 4.2.0 Build id: I20120608-1400.
I put the stack trace in attachment. If you need further info for the investigation let me know.
Thanks Wink
  • Attachment: xcore.log
    (Size: 4.13KB, Downloaded 278 times)
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #924743 is a reply to message #924062] Thu, 27 September 2012 01:04 Go to previous messageGo to next message
Régent,
Please try the latest maintenance stream build:
http://download.eclipse.org/modeling/emf/emf/updates/2.8.x
On 26/09/2012 3:10 PM, Régent L Archevêque wrote:
> Hi Ed,
> Thanks ;)
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #926338 is a reply to message #924743] Fri, 28 September 2012 10:56 Go to previous messageGo to next message
Hi Ed,
I installed a fresh version of Eclipse 4.2 + EMF 2.8.x as you recommended. I tried and I got similar issue. I created a simple example (see the attachment) that illustrates the issue. There are two models: 1 ecore + 1 xcore. The xcore project refers to one class of the ecore project but I get the "Couldn't resolve reference to GenBase 'EcoreProjectClass'.
Thanks Wink
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #926431 is a reply to message #926338] Fri, 28 September 2012 12:43 Go to previous messageGo to next message
Régent,
Yes, workspace projects need an Xtext nature in order to be indexed by
the Xtext builder and that's needed for the qualified names to be
visible in Xcore models.
On 28/09/2012 4:56 PM, Régent L Archevêque wrote:
> Hi Ed,
> Thanks ;)
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #926496 is a reply to message #926431] Fri, 28 September 2012 14:15 Go to previous messageGo to next message
Understood. Thanks Ed.
When I add the XText Nature the problem is fixed if both projects are located in the same workspace. But on my side, the ecore project is an installed plugin and the xcore is the only project in the workspace. What should I do to make that work. I am wondering because I can refer EMF Meta-Model Classes such as EClass, EObject with no problem but it does not work with my models.
Thanks again for you support
Regent Wink
Re: [XCore] CompoundXtextEditorCallback - Was configured with another client or not configured at a [message #926514 is a reply to message #926496] Fri, 28 September 2012 14:31 Go to previous message
Régent,
Comments below.
That should just work... That plugin has the model folder in the jarred
bundle and it's properly registered in the plugin.xml?
As a work around, you can import it into your workspace..
There is a bug that models with cross project references don't work, but
the fix for that (in Xtext) won't be in the maintenance stream:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=390132
> Regent ;)
Previous Topic:XCore install issues
Next Topic:[EMF Compare] Cross-references not added during merge, bug?
Current Time: Wed Jul 23 03:14:08 EDT 2025
Powered by FUDForum. Page generated in 0.27959 seconds
