Home » Archived » Visual Editor (VE) » Swing Tabbed Pane background color ignored
Swing Tabbed Pane background color ignored [message #92282] Fri, 27 May 2005 13:46 Go to next message
Originally posted by: richard.pimentel.hci.utah.edu
the problem I am having is the background color I am setting for a Swing
tabbed pane is ignored when I run the application. The color is correct in
VE and when I change it is dutifully changed in VE but when I run the app
it the tab is always the default grey. I am using the following versions:
Eclipse SDK 3.0.2
EMF Runtime 2.0.2
GEF Runtime 3.0.1
VE Runitme M2050504
I have included code from the main class. It instances another visual
class (Extract) that is composed of a pane with several panels, buttons,
etc. Any help with this would be appreciated.
package ManualMergeExtract;
import javax.swing.JFrame;
import javax.swing.JTabbedPane;
public class MainFrame extends JFrame
private JTabbedPane tabbedPane = null;
private Extract extractPane = null;
* This method initializes jTabbedPane
* @return javax.swing.JTabbedPane
private JTabbedPane getTabbedPane() {
if (tabbedPane == null) {
try {
tabbedPane = new JTabbedPane();
extractPane = new Extract();
tabbedPane.addTab("Extract", extractPane);
tabbedPane.setFont(new java.awt.Font("MS Sans Serif",
java.awt.Font.PLAIN, 12)); // Generated
tabbedPane.setBackground(new java.awt.Color(236,233,216)); // Generated
catch (java.lang.Throwable e) {
// TODO: Something
return tabbedPane;
public static void main(String[] args)
new MainFrame();
public MainFrame() {
super();
initialize();
private void initialize() {
this.setBackground(java.awt.Color.white); // Generated
this.setName("mainFrameTPane"); // Generated
this.setFont(new java.awt.Font("MS Sans Serif", java.awt.Font.PLAIN,
12)); // Generated
this.setSize(620, 700);
this.setTitle("Extract-O-Merge"); // Generated
this.setContentPane(getTabbedPane()); // Generated
this.setVisible(true); // Generated
} // @jve:decl-index=0:visual-constraint="10,10"
Re: Swing Tabbed Pane background color ignored [message #92327 is a reply to message #92282] Sat, 28 May 2005 01:35 Go to previous message
Originally posted by: no.ddress.here
In article <304e8c62c69ddcb7d9efe63b1ec75eee$1@www.eclipse.org>,
richard.pimentel@hci.utah.edu says...
> VE
Long standing Swing issue:
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=4690946
Re: Swing Tabbed Pane background color ignored [message #607842 is a reply to message #92282] Sat, 28 May 2005 01:35 Go to previous message
> VE
Previous Topic:VE Update Manager on the Web Page
Next Topic:Visual Editor update site
Current Time: Fri Jul 18 22:03:35 EDT 2025
Powered by FUDForum. Page generated in 0.03871 seconds
