Home » Modeling » ATL » [ATL] model element references in input model(How can I work with model element references in ATL)
[ATL] model element references in input model [message #922859] Tue, 25 September 2012 08:04 Go to next message
I have a similar problem as described here (http://eclipse.org/forums/index.php/t/167517/), unfortunately this thread has no answer.
Situation: I used EMF to create an Ecore metamodel, generated a model editor, and build a model with it. All fine. Please consider the simplified model below. In this model I set some properties of model elements to reference other model elements. In this case the element "ExampleContract1" has a clientDependency to the other element "ExampleContract2". The model editor creates a link like "#//ShippingContract/ExampleContract2".
(the http part is removed from the code headers otherwise I was not allowed to post)
<soaML:SoaMLModel xmlns:xsi="w3.org/2001/XMLSchema-instance" xmlns:soaML="soaML.ecore" xmlns:uml="eclipse.org/uml2/3.0.0/UML" name="Case study">
 <packagedElement xsi:type="soaML:SoaMLModel" name="ShippingContract">
      <packagedElement xsi:type="soaML:ServiceContract" name="ExampleContract1" clientDependency="#//ShippingContract/ExampleContract2"/>
      <packagedElement xsi:type="soaML:QoSContract" name="ExampleContract2" />
</packagedElement>
.... snip ....
Now when I try to load this model in a ATL transformation (as input model) it generates the following error: "Error loading platform:/resource/project/model/Case.soaml: The feature 'hippingContract' is not a valid feature". With other words, it breaks on the reference.
Why does this not work? Hope someone can give me some explanations or hints?
Niels
[Updated on: Tue, 25 September 2012 08:50] by Moderator
Re: [ATL] model element references in input model [message #923266 is a reply to message #922859] Tue, 25 September 2012 15:23 Go to previous messageGo to next message
Op 25-09-12 14:04, Niels S schreef:
> Hello,
> no answer.
> Situation, i used EMF to create an Ecore metamodel, generated a model editor,
> (the http part is remove from the code headers otherwise I was not allowed to
> post)
> study">
> </packagedElement>
> ... snip ....
> Regards,
> Niels
That doesn't look like standard XMI to me... Did you use any special settings
in the .genmodel file? Or did you generate the .ecore from an .xsd file? In
any case, standard EMF XMI includes an xmlns:xmi header and uses XPath
expressions for references. Yours would be something like
"/0/@packagedElement.0/@packagedElement.1".
Normally, this custom XML format is not a problem, unless you load your
metamodel from file instead of namespace URI. If you load the metamodel from
file, ATL will use a standard XMIResourceImpl parser, which does not
understand your specific XML format.
Dennis
Re: [ATL] model element references in input model [message #924349 is a reply to message #923266] Wed, 26 September 2012 15:23 Go to previous messageGo to next message
Hello Dennis,
Thanks for your answer.
I created the Ecore file myself (just by clicking the metamodel in a EcoreDiagram), there's is just one special thing: it extends UML2 metamodel. I.e., several elements have a UML!<class> supertype.
(When I inspect the metamodel's Ecore file with the OclInEcore editor I see nothing stranges (just the import "import uml : '/plugin/org.eclipse.uml2.uml/model/UML.ecore#/';").
I would have been really happy if the generated editor uses XPath references as you describe, however, it make these other kind of references. Furthermore, I use default GenModel settings to generate the editor.
Maybe it is because I try to extend UML?
Any further ideas are welcome....
[Updated on: Wed, 26 September 2012 15:23] by Moderator
Re: [ATL] model element references in input model [message #928557 is a reply to message #924349] Sun, 30 September 2012 15:10 Go to previous messageGo to next message
Op 26-09-12 21:23, Niels S schreef:
> Hello Dennis,
> Any further ideas are welcome?
Perhaps it indeed has something to do with UML. The UML metamodel is
configured to use XMI IDs instead of XPath expressions. Better check with the
EMF and UML newsgroups as well.
Dennis
Re: [ATL] model element references in input model [message #929338 is a reply to message #928557] Mon, 01 October 2012 07:32 Go to previous message
Okay, I will do. If I find any solution I will let it know in this topic.
For now I can continue by manually converting the references to XPath expressions. I tested them and these work fine in ATL.
Previous Topic:ADT in RCP application
Next Topic:[ATL] how can I know the path of the model output and xmiID of newly created elements?
Current Time: Wed Jul 23 16:17:07 EDT 2025
Powered by FUDForum. Page generated in 0.26340 seconds
