Home » Language IDEs » Java Development Tools (JDT) » Ctrl+Shift+I shortcut to inspect: is it gone?
Ctrl+Shift+I shortcut to inspect: is it gone? [message #921442] Mon, 24 September 2012 01:49 Go to next message
Hello all,
I'm using Juno now, but while I'm debugging I can't see the Ctrl+Shift+I
shortcut bound to "Inspect" command. Is it normal? Was it removed?
It's very annoying! I couldn't find any reference on Bugzilla for this...
Thanks in advance,
Mauro.
Re: Ctrl+Shift+I shortcut to inspect: is it gone? [message #922229 is a reply to message #921442] Mon, 24 September 2012 17:20 Go to previous messageGo to next message
I haven't seen this particular instance and for me this shortcut works fine in Juno.
However, you might want to check your error log if there's any handler conflict or anything related to key bindings.
You're definitely not the first person to see problems with shortcuts in Juno ...
Re: Ctrl+Shift+I shortcut to inspect: is it gone? [message #922560 is a reply to message #922229] Tue, 25 September 2012 01:47 Go to previous messageGo to next message
> fine in Juno.
> Juno ...
You anticipated me, in fact I see this in my log:
Re: Ctrl+Shift+I shortcut to inspect: is it gone? [message #922561 is a reply to message #922229] Tue, 25 September 2012 01:49 Go to previous messageGo to next message
> fine in Juno.
> Juno ...
eclipse.buildId=I20120608-1400
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86_64 -debug -consoleLog
Warning
Mon Sep 24 11:33:05 CEST 2012
A conflict occurred for CTRL+SHIFT+I:
Binding(CTRL+SHIFT+I,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Inspect,Inspect,
Inspect result of evaluating selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command
category,true),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.dialogAndWindow,,,system)
ParameterizedCommand(Command(org.eclipse.php.debug.ui.commands.Inspect,Inspect,
category,true),
,,true),null),
What I can't understand is what this shortcut is conflicting with... It
seems like it's conflicting with itself?
Mauro.
Re: Ctrl+Shift+I shortcut to inspect: is it gone? [message #922569 is a reply to message #922229] Tue, 25 September 2012 01:56 Go to previous message
I opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=390291
Thanks for you help!
Mauro.
Previous Topic:Debugger doesn't remain paused
Next Topic:eclipse IDE shows ctrl shortcut instead of running it
Current Time: Sun Jul 20 22:34:54 EDT 2025
Powered by FUDForum. Page generated in 0.08666 seconds
