Home » Language IDEs » Java Development Tools (JDT) » Debugger doesn't remain paused(Debugger keeps running)
Debugger doesn't remain paused [message #922345] Mon, 24 September 2012 20:14 Go to next message
I'm using Eclipse Juno with JDK 1.6. I'm trying to debug an application and while I'm examining data at a breakpoint, the app starts running again the application terminates.
The app is multi-threaded. But none of the threads terminate the entire application.
Is there something that I need to set/unset?
This is very frustrating.
Les
Re: Debugger doesn't remain paused [message #922352 is a reply to message #922345] Mon, 24 September 2012 20:25 Go to previous messageGo to next message
If you can reproduce this using a small example program, you should file a bug against JDT/Debug.
Re: Debugger doesn't remain paused [message #922353 is a reply to message #922345] Mon, 24 September 2012 20:28 Go to previous message
Oops! Just found a problem where the return to a service ended and hence the JUnit cleanup was destroying things. My bad.
Les
Previous Topic:Check is type imported
Next Topic:Ctrl+Shift+I shortcut to inspect: is it gone?
Current Time: Sun Jul 20 20:49:28 EDT 2025
Powered by FUDForum. Page generated in 0.07323 seconds
