Home » Eclipse Projects » Equinox » Reverse bundle resolving
Reverse bundle resolving [message #92142] Tue, 17 July 2007 07:23 Go to next message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Hello
I have a class name. How can I determine in which bundle it is declared?
TIA
Chris
Re: Reverse bundle resolving [message #92174 is a reply to message #92142] Tue, 17 July 2007 09:48 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Chris,
PackageAdmin does this.
http://www2.osgi.org/javadoc/r4/org/osgi/service/packageadmi n/PackageAdmin.html#getBundle(java.lang.Class)
HTH
-Simon
"Krzysztof Daniel" <krzysztofHMMMMdaniel@gmail.com> wrote in message
news:f7i8rc$uau$1@build.eclipse.org...
> Hello
> TIA
> Chris
Re: Reverse bundle resolving [message #92186 is a reply to message #92174] Tue, 17 July 2007 09:48 Go to previous messageGo to next message
Hi Simon,
Thanks for interest.
I think I have not made it clear enough - I have class *name*, which is
String type. And PackageAdmin takes Class as a paremeter...
Chris
Re: Reverse bundle resolving [message #92199 is a reply to message #92186] Tue, 17 July 2007 10:39 Go to previous messageGo to next message
Yep -- misunderstood what you were looking for.
You can work backwards from the classes package name to find the set of
bundles that export them.
Try PackageAdmin's --
public ExportedPackage[] getExportedPackages(Bundle bundle)
-Simon
news:f7ihc9$uau$2@build.eclipse.org...
> Hi Simon,
> Chris
Re: Reverse bundle resolving [message #92214 is a reply to message #92199] Tue, 17 July 2007 10:41 Go to previous messageGo to next message
I meant...
public ExportedPackage[] getExportedPackages(java.lang.String name)Gets the
exported packages for the specified package name.
"Simon Kaegi" <simon_kaegi@ca.ibm.com> wrote in message
news:f7ikaj$1li$1@build.eclipse.org...
> -Simon
>> Hi Simon,
>> Chris
Re: Reverse bundle resolving [message #92231 is a reply to message #92214] Tue, 17 July 2007 10:46 Go to previous messageGo to next message
Simon,
exported packages are packages contained by bundle, or defined as exported?
Chris
Re: Reverse bundle resolving [message #92244 is a reply to message #92231] Tue, 17 July 2007 10:54 Go to previous messageGo to next message
Just those defined as exported. ;)
I think you'll have a hard time getting at the other packages -- no metadata
to be had.
news:f7ikp6$uau$3@build.eclipse.org...
> Simon,
> exported?
> Chris
Re: Reverse bundle resolving [message #92259 is a reply to message #92186] Tue, 17 July 2007 11:15 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
You can't. You get a .class, and then it figures it out. If you can't get a class, you don't have a dependency on that bundle.
Alex.
Re: Reverse bundle resolving [message #92274 is a reply to message #92244] Tue, 17 July 2007 11:54 Go to previous message
There is always the brute force way:
You get all installed bundles and use Bundle.loadClass() to find the
class. Then use PackageAdmin.getBundle(Class) to find the bundle.
So, Daniel, what exactly are you trying to accomplish?
> to be had.
>> Simon,
>> exported?
>> Chris
Previous Topic:Re: Dynamic extensions in 3.2 with custom class loader
Next Topic:jetty 6 osgi support
Current Time: Sat Nov 08 22:51:56 EST 2025
Powered by FUDForum. Page generated in 0.05164 seconds
