| Debugging the resolution of a CVS provider based on a tag? [message #921896] | Mon, 24 September 2012 10:34 |  |
| Eclipse User  |  |  |  |  | I have added an Advisor Node to my cquery to get a particular version of some code from a CVS repository. Everything works fine when I specify a timestamp at the approximate time of a specific CVS tag, but when I specify the CVS tag itself instead of the timestamp I get the following kind of errors for some plugins:
 ERROR   [0002] : No suitable provider for component xxx
 ERROR   [0002] : No suitable provider for component xxx was found in searchPath yyy
 ERROR   [0002] : Rejecting provider <path> No component match was found
 The provider specified by <path> does contain the plugin in the CVS repository for the tag in the advisor node. What might keep Buckminster from finding it? Can I get more information about the resolution somehow?
 I specify the timestamp in the Selection Criteria detail view of the cquery editor and I specify the tag in the Branch/Tag path field as: /V8_3_5-03
 I'm using Eclipse 3.7.1 with Buckminster 1.4.0 installed.
FUDForum. Page generated in 0.03013 seconds
