Home » Modeling » EMF » NoClassDefFoundError on AggregateProxyPackage
NoClassDefFoundError on AggregateProxyPackage [message #921612] |
Mon, 24 September 2012 05:18  |
[I already asked in the QVT group but the more I analyze this the more I
feel the root cause is in the EMF part of my eclips installation.]
I'm getting the following fatal error with a QVT project:
java.lang.NoClassDefFoundError: Could not initialize class
org.eclipse.emf.facet.aggregate.metamodel.v0_2_0.aggregate.internal.aggregateProxy.AggregateProxyPackage
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at
sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:43)
at
sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:140)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:936)
at java.lang.reflect.Field.getFieldAccessor(Field.java:917)
at java.lang.reflect.Field.get(Field.java:376)
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescriptor.getEPackage(RegistryReader.java:273)
at
org.eclipse.emf.ecore.impl.EPackageImpl$1.getEPackage(EPackageImpl.java:162)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage(EPackageRegistryImpl.java:127)
at
org.eclipse.m2m.internal.qvt.oml.emf.util.mmregistry.EmfMetamodelDesc.getModel(EmfMetamodelDesc.java:64)
The OSG console says:
osgi> ss agg
"Framework is launched."
id State Bundle
289 STARTING org.eclipse.birt.data.aggregation_4.2.0.v20120611
539 ACTIVE org.eclipse.emf.facet.aggregate.doc_0.2.0.v201206120903
540 ACTIVE
org.eclipse.emf.facet.aggregate.metamodel_0.2.0.v201206120903
541 ACTIVE
org.eclipse.emf.facet.aggregate.metamodel.notgenerated_0.2.0.v201206120903
I can't open the class AggregateProxyPackage though in the editor
(Ctrl+Shift+T).
What could possibly be wrong with my installation?!?
TIA
Marius
Re: NoClassDefFoundError on AggregateProxyPackage [message #921865 is a reply to message #921779] |
Mon, 24 September 2012 09:55   |
Marius,
I could imagine that if different threads try to initialize different
packages that depend on each other, things might go wrong. Even locks
don't help in this kind of case; they'd just cause deadlock. If you
know the set of packages you're going to use, it's a good workaround to
initialize them early.
On 24/09/2012 2:15 PM, Marius Gröger wrote:
> On 24.09.2012 13:49, Marius Gröger wrote:
>> Thanks, that helped a lot. I think I'm now able to pinpoint a bug in the
>> initialization order of this facet stuff:
>> b) is there any work around?
> Notice that when I call:
> AggregatePackage pkg = AggregatePackage.eINSTANCE;
> in an IStartup class, the issue goes away. Apparently in my specific use
> case (QVT, XSD Ecore models) the AggregateProxyPackage is tried to be
> initialized first, which does not work due to a bug in the init code.
> Regards
> Marius
Re: NoClassDefFoundError on AggregateProxyPackage [message #921890 is a reply to message #921865] |
Mon, 24 September 2012 10:24   |
On 24.09.2012 15:55, Ed Merks wrote:
> Marius,
Hm. Well, the issue appears fully reproducible with my setup, and that
includes(!) both my development Eclipse instance as well as runtime. It
seems to me that consistently AggreateProxyPackage is initialized first.
It really doesn't looks to be a glitch. I really wonder if this works
anywhere correctly. Putting it differently: as some knowing all this so
much better - from what place would you say is AggregatePackage are
AggreateProxyPackage "usually" accessed/inited first?
Btw, notice my usage in conjunction with QVT and XSD Ecore, which
appears not to be used _that_ widely.
Secondly, my work around is a magic plugin to be dropped in "dropins".
While we will be able to live with this situation, it limits a bit the
trust in the selected technology.
So if it's ok for you, I'll at least file it as a bug.
Marius
Re: NoClassDefFoundError on AggregateProxyPackage [message #921970 is a reply to message #921890] |
Mon, 24 September 2012 11:54   |
Marius,
Comments below.
>> Marius,
I'm not sure which depends on which, but even that shouldn't matter. I
assume they're not mutually dependent but that could be the case as
well, but then they'd be in the same project
You have to keep in mind that this package initialization logic has
existed for well over a decade, with fixes along the way. There is not
a general
As long as there's a reproducible test case, that's fine, but if that
involves "install plugins from project x, y, and z," then it will be x,
y, and z's responsibility to investigate so open a bug for those. If it
involves "here are some zipped projects you can import into any
workspace where EMF is installed and run blah to see the problem," then
I'll have a look.
> Regards
> Marius
Current Time: Fri Jul 25 20:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.07668 seconds
