Home » Newcomers » Newcomers » Command line used by eclipse?
Command line used by eclipse? [message #92105] Thu, 04 August 2005 10:21 Go to next message
Originally posted by: alapalaya.hotmail.com
there is a way to know the command line used by eclipse to launch an
application inside the IDE?
thanks in advance
Re: Command line used by eclipse? [message #92124 is a reply to message #92105] Thu, 04 August 2005 10:27 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
Ala wrote:
> thanks in advance
If I understand the question...
Just select the class you want to run and right click.
Then select Run.
You will now see all of he run options for this particular class.
This is all of the same for Debug but just select debug.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Command line used by eclipse? [message #92160 is a reply to message #92105] Thu, 04 August 2005 10:44 Go to previous message
in the Debug view, select a launch (after you start it) and see Properties.
A dialog opens and you see: "Process Information" and "Command Line:"
Command Line contains what you're looking for
/adam
Previous Topic:Child popup window (SWT)
Next Topic:Greater than signs ( >>> )in project explorer
Current Time: Wed Oct 08 05:09:50 EDT 2025
Powered by FUDForum. Page generated in 0.08389 seconds
