Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP Manual Test Execution with Attachment
TPTP Manual Test Execution with Attachment [message #92005] Wed, 31 January 2007 08:41 Go to next message
I try to attache screenshots to an execution of an TPTP manual test.
But this causes an error.
Must I preset something to use this function.
Yours sincerely, Krista Haldenwang
Error message in the execution:
java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/xml/type/XMLTypeFactory
at
org.eclipse.hyades.test.common.event.ExecutionEvent.addXMLAn notations(ExecutionEvent.java:426)
at
org.eclipse.hyades.test.common.event.ExecutionEvent.toString (ExecutionEvent.java:310)
at
org.eclipse.tptp.test.manual.runner.core.internal.ManualTest Runner.logEvent(ManualTestRunner.java:290)
at
org.eclipse.tptp.test.manual.runner.core.internal.ManualTest Runner$2.log(ManualTestRunner.java:251)
at
org.eclipse.tptp.test.manual.runner.ui.internal.ManualTestVi ew.selectNextTaskToExecute(ManualTestView.java:575)
at
org.eclipse.tptp.test.manual.runner.ui.internal.ManualTestVi ew.access$6(ManualTestView.java:468)
at
org.eclipse.tptp.test.manual.runner.ui.internal.ManualTestVi ew$12.run(ManualTestView.java:446)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.tptp.test.manual.runner.ui.internal.ManualTestVi ew$11.handleEvent(ManualTestView.java:403)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at
org.eclipse.tptp.test.manual.runner.ui.internal.ManualTestVi ew.open(ManualTestView.java:138)
at
org.eclipse.tptp.test.manual.runner.core.internal.ManualTest Runner.main(ManualTestRunner.java:199)
Re: TPTP Manual Test Execution with Attachment [message #96111 is a reply to message #92005] Tue, 17 April 2007 07:25 Go to previous message
Hi Krista,
There are no special presets to use this feature. This appears to be a
configuration issue with the EMF dependency. What version of TPTP are you
currently using? Are you using the Agent Controller or Integrated Agent
Controller?
This function has been successfully tested for each stable build and
release driver so I would recommend moving to the next stable build and
release drvier.
Paul
"Krista Haldenwang" <hatsirk@gmx.de> wrote in message
news:2ab883b1d59948758cf4d29d6bf2e620$1@www.eclipse.org...
>I try to attache screenshots to an execution of an TPTP manual test. But
>this causes an error. Must I preset something to use this function.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:testing outside eclipse
Next Topic:org.eclipse.hyades.test.core dependencies
Current Time: Sun Nov 09 16:38:01 EST 2025
Powered by FUDForum. Page generated in 0.24867 seconds
