Home » Modeling » TMF (Xtext) » Code completion for Java imports
Code completion for Java imports [message #918848] Fri, 21 September 2012 08:02 Go to next message
This should be a common topic but Google didn't turn up anything useful: How do I get code completion in the DSL editor for a Java-like import statement?
import java.util.D|
should offer "java.util.Date"
How do I do that?
A. Digulla
Re: Code completion for Java imports [message #920019 is a reply to message #918848] Sat, 22 September 2012 12:34 Go to previous messageGo to next message
As far as I know, there is no direct support for that when using
'importedNamespace'...
the html routing example,
http://www.eclipse.org/Xtext/7languagesDoc.html#httpRouting , uses
"validated imports":
"in the routing DSL we use real cross-references to Java types in
imports. Although it is not as convenient to implement, it has the
advantage having imports validated and getting proper content assist in
your imports section. For future releases it is planned to significantly
improve support for import sections for JVM languages including nice IDE
features like organize imports. "
hope this helps
Lorenzo
> statement?
> import java.util.D|
> How do I do that?
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Code completion for Java imports [message #922659 is a reply to message #920019] Tue, 25 September 2012 04:02 Go to previous messageGo to next message
Thanks, the example grammar led me on the right track.
But one more question: What do you mean by "when using 'importedNamespace'"? What is "importedNamespace"?
A. Digulla
Re: Code completion for Java imports [message #927268 is a reply to message #922659] Sat, 29 September 2012 08:58 Go to previous message
I mean this one (from the documentation), which, I assumed, was your
initial setting:
Imports can be defined in a very convenient way with Xtext. If you use
the name importedNamespace in a parser rule, the framework will treat
the value as an import. It even supports wildcard and handles them as
expected:
Import:
'import' importedNamespace = QualifiedNameWithWildcard
QualifiedNameWithWildcard:
QualifiedName '.*'?
Previous Topic:Multipage Editor with Xtext
Next Topic:Permission of the generated files
Current Time: Wed Jul 23 14:51:07 EDT 2025
Powered by FUDForum. Page generated in 0.04077 seconds
