Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] can't deserialize EObjects which contain Teneo proxies
[Teneo] can't deserialize EObjects which contain Teneo proxies [message #91780] |
Wed, 25 July 2007 15:06  |
Originally posted by: eclipse_news.firstnamelastname.ch
I have a problem when I try to deserialize a XMI that contains Teneo
Proxies:
ResourceSet rs = new ResourceSetImpl();
Resource teneoRes = rs.createResource(
URI.createURI("hibernate://?dsname=library&query1=from Book"));
teneoRes.load(null);
Resource xmiStoreRes = rs.createResource(
URI.createFileURI("transfer.xmi"));
xmiStoreRes.getContents().addAll(teneoRes.getContents());
xmiStoreRes.save(null);
Resource xmiLoadRes = rs.createResource(
xmiLoadRes.load(null);
results in:
Exception in thread "main"
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The
reference to entity "query1" must end with the ';' delimiter.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:199)
the saved xmi looks like this:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:org.eclipse.example.library="http:///org/eclipse/example/library.ecore">
<org.eclipse.example.library:Book title="b1" id="196608">
<titlePage href="hibernate://?dsname=library&query1=from
Book#TitlePage|id=131072"/>
</org.eclipse.example.library:Book>
<org.eclipse.example.library:Book title="b2" id="196609">
<author href="hibernate://?dsname=library&query1=from
Book#Writer|id=163840"/>
Book#TitlePage|id=131073"/>
</xmi:XMI>
Thanks in advance,
Tom.
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #92001 is a reply to message #91951] |
Thu, 26 July 2007 14:31   |
--------------060807090600030702080102
Thomas,
Probably you need to use this option if your URIs contain characters
with special XML meaning...
* Skip escaping special characters, such as '&' char, in URIs
during XML serialization.
* The default is <code>Boolean.TRUE</code>. To enforce escaping
special characters, set this
* option to <code>Boolean.FALSE</code>.
String OPTION_SKIP_ESCAPE_URI = "SKIP_ESCAPE_URI";
Thomas Kuhn wrote:
> Hi Martin,
> below the complete stack trace.
> Thomas
> at
> at
> org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
> at ch.thomaskuhn.library_test.RetrieveData.main(RetrieveData.ja va:39)
> Caused by: org.xml.sax.SAXParseException: The reference to entity
> at
> org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseExc eption(Unknown
> Source)
> at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknow n
> Source)
> at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown
> Source)
> Source)
> at org.apache.xerces.impl.XMLScanner.reportFatalError(Unknown Source)
> at org.apache.xerces.impl.XMLScanner.scanAttributeValue(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanAt tribute(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
> Source)
> at
> org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
> Source)
> at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
> at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
> at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
> at javax.xml.parsers.SAXParser.parse(Unknown Source)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
> ... 4 moreException in thread "main"
> at
> at
> at
> at
> at
> Source)
> Source)
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 4 more
> Martin Taal wrote:
>> Hi Thomas,
>> Can you post the complete stacktrace? I mean is there an underlying
>> sax (or other) exception?
>> gr. Martin
>> Thomas Kuhn wrote:
>>> Hi,
>>> Proxies:
>>> results in:
>>> at
>>> </xmi:XMI>
>>> Thanks in advance,
>>> Tom.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Thomas,<br>
<br>
with special XML meaning...<small><br>
</small>
<blockquote><small> /**</small><big><br>
</big><small> * Skip escaping special characters, such as '&'
char, in URIs during XML serialization.</small><big><br>
</big><small> * The default is
<code>Boolean.TRUE</code>. To enforce escaping special
characters, set this </small><big><br>
</big><small> * option to <code>Boolean.FALSE</code>.</small ><big><br>
</big><small> */</small><big><br>
</big><small> String OPTION_SKIP_ESCAPE_URI = "SKIP_ESCAPE_URI";</small><br>
</blockquote>
<br>
Thomas Kuhn wrote:
<blockquote cite="mid:f8aj9h$v4n$1@build.eclipse.org" type="cite">Hi
Martin,
<br>
<br>
<br>
<br>
<br>
<br>
Thomas
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
<br>
Source)
<br>
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
<br>
Source)
<br>
<br>
at
<br>
... 4 more
<br>
<br>
Martin Taal wrote:
<br>
<blockquote type="cite">Hi Thomas,
<br>
Can you post the complete stacktrace? I mean is there an underlying sax
<br>
<br>
gr. Martin
<br>
<br>
Thomas Kuhn wrote:
<br>
<blockquote type="cite">Hi,
<br>
<br>
Proxies:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
results in:
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<xmi:XMI xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:org.eclipse.example.library=<a class="moz-txt-link-rfc2396E" href="http:///org/eclipse/example/library.ecore">"http:///org/eclipse/example/library.ecore"</a>>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</xmi:XMI>
<br>
<br>
<br>
Thanks in advance,
<br>
<br>
Tom.
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------060807090600030702080102--
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #92016 is a reply to message #92001] |
Sat, 28 July 2007 10:15  |
Hi Ed,
It works!
Thanks a lot,
Tom.
Ed Merks wrote:
> Thomas,
> Thomas Kuhn wrote:
>> Hi Martin,
>> Thanks,
>> Thomas
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 4 more
>> Martin Taal wrote:
>>> Hi Thomas,
>>> gr. Martin
>>> Thomas Kuhn wrote:
>>>> Hi,
>>>> Proxies:
>>>> results in:
>>>> at
>>>> </xmi:XMI>
>>>> Thanks in advance,
>>>> Tom.
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #608928 is a reply to message #91780] |
Thu, 26 July 2007 02:13  |
Hi Thomas,
Can you post the complete stacktrace? I mean is there an underlying sax (or other) exception?
gr. Martin
Thomas Kuhn wrote:
> Proxies:
> results in:
> </xmi:XMI>
> Thanks in advance,
> Tom.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #608941 is a reply to message #91872] |
Thu, 26 July 2007 12:48  |
Hi Martin,
Thomas
at
at
at
at
Source)
at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknow n Source)
at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
at org.apache.xerces.impl.XMLScanner.scanAttributeValue(Unknown Source)
at
Source)
at
Source)
at
Source)
at
Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
... 4 more
Martin Taal wrote:
> Hi Thomas,
> gr. Martin
> Thomas Kuhn wrote:
>> Hi,
>> Proxies:
>> results in:
>> at
>> </xmi:XMI>
>> Thanks in advance,
>> Tom.
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #608947 is a reply to message #91951] |
Thomas,
Thomas Kuhn wrote:
> Hi Martin,
> Thomas
> at
> at
> at
> at
> at
> Source)
> Source)
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> Source)
> Source)
> Source)
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 4 more
> Martin Taal wrote:
>> Hi Thomas,
>> gr. Martin
>> Thomas Kuhn wrote:
>>> Hi,
>>> Proxies:
>>> results in:
>>> at
>>> </xmi:XMI>
>>> Thanks in advance,
>>> Tom.
<html>
<head>
</head>
Thomas,<br>
<br>
</small>
</blockquote>
<br>
Martin,
<br>
<br>
<br>
<br>
<br>
<br>
Thomas
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
<br>
Source)
<br>
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
at
Source)
<br>
Source)
<br>
Source)
<br>
<br>
Source)
<br>
<br>
at
<br>
... 4 more
<br>
<br>
Martin Taal wrote:
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
Thomas Kuhn wrote:
<br>
<br>
<br>
Proxies:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
results in:
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</xmi:XMI>
<br>
<br>
<br>
Thanks in advance,
<br>
<br>
Tom.
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: [Teneo] can't deserialize EObjects which contain Teneo proxies [message #608950 is a reply to message #92001] |
Hi Ed,
It works!
Thanks a lot,
Tom.
Ed Merks wrote:
> Thomas,
> Thomas Kuhn wrote:
>> Hi Martin,
>> Thanks,
>> Thomas
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 4 more
>> Martin Taal wrote:
>>> Hi Thomas,
>>> gr. Martin
>>> Thomas Kuhn wrote:
>>>> Hi,
>>>> Proxies:
>>>> results in:
>>>> at
>>>> </xmi:XMI>
>>>> Thanks in advance,
>>>> Tom.
Current Time: Fri Jul 18 17:24:56 EDT 2025
Powered by FUDForum. Page generated in 0.05341 seconds
