Home » Eclipse Projects » Eclipse 4 » Howto contribute a perspective to a perspective stack?
Howto contribute a perspective to a perspective stack? [message #918842] Fri, 21 September 2012 07:54 Go to next message
I want to contribute a complete perspective including the views from a
fragment.e4xmi to the application model.
Inside the Application.e4.xmi I have defined:
<children xsi:type="basic:TrimmedWindow"
xmi:id="_XwsN6gMWEeKkEbp87BcYwQ" label="Application" width="500"
height="400">
<children xsi:type="advanced:PerspectiveStack"
xmi:id="_XwsN8gMWEeKkEbp87BcYwQ" elementId="de.ww.perspectivestack"
selectedElement="_XwsN8wMWEeKkEbp87BcYwQ">
<children xsi:type="advanced:Perspective"
xmi:id="_XwsN8wMWEeKkEbp87BcYwQ" elementId="de.ww.core.perspective"
label="Perspective">
<children .........
At my fragment.e4xmi I have defined the following Model Fragment:
<fragments xsi:type="fragment:StringModelFragment"
xmi:id="_kAkdUAPVEeKUqvnYpyiNPg" featurename="children"
parentElementId="de.ww.perspectivestack">
<elements xsi:type="advanced:Perspective"
xmi:id="_pZ4EUAPVEeKUqvnYpyiNPg" elementId="de.ww.docmgmt.perspective"
label="DocMgmt">
<children xsi:type="basic:PartSashContainer"
xmi:id="_BVhKoAPBEeKUqvnYpyiNPg"
elementId="de.ww.docmgmt.partsashcontainer.main" horizontal="true">
</children>
</elements>
</fragments>
I also add some more model fragments with handlers and commands.
So I add a Handler to switch to the defined perspective with the
following code:
@Execute
public void execute(MApplication app, EModelService modelService,
EPartService partService) {
MPerspective element =
(MPerspective) modelService.find("de.ww.docmgmt.perspective", app);
partService.switchPerspective(element);
But this method doesn't find the defined perspective and the
modelservice returns a null.
What have I do wrong???
Thanks in advance
Heiko
Re: Howto contribute a perspective to a perspective stack? [message #918869 is a reply to message #918842] Fri, 21 September 2012 08:27 Go to previous messageGo to next message
Hi Heiko
your Handler-code looks good to me. I am doing the same thing, so it should work.
To test what your model looks like after start of the application, you can use the e4 live model editor.
1) You need to add some bundles to your product:
- org.eclipse.e4.tools.emf.liveeditor
- org.eclipse.e4.tools.emf.ui
- org.eclipse.e4.tools.emf.ui.script.js
and the required plug-ins
2) After you start the product like this, press Alt-Shift-F9
Now you can inspect your model and check, if all the elements are there and if the IDs are all correct.
Hope this helps!
Christoph
Re: Howto contribute a perspective to a perspective stack? [message #918890 is a reply to message #918869] Fri, 21 September 2012 08:51 Go to previous messageGo to next message
Hi Christoph,
thanks for the tip, I have read about it but now used until now - it's a
nice feature. :)
It helps me to see that my defined perspective are not available at the
model.
And it helps to start an app with the option "clear workspace" sometime. :)
Now it works.
Greetings
Heiko
Am 21.09.2012 14:27, schrieb Christoph Keimel:
> Hi Heiko
> should work.
> Hope this helps!
> Christoph
Re: Howto contribute a perspective to a perspective stack? [message #919006 is a reply to message #918890] Fri, 21 September 2012 11:35 Go to previous message
Hi Heiko
Great!
You might be interessted in this bug discussion concerning fragment contributions:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389663
Greetings
Christoph
Previous Topic:Howto restart an e4 RCP application
Next Topic:DNDAddon Trouble
Current Time: Fri Jul 25 10:22:54 EDT 2025
Powered by FUDForum. Page generated in 0.15436 seconds
