Re: Binding to "nested" properties [message #918272 is a reply to message #918198] |
Thu, 20 September 2012 18:32  |
Hi Mark,
think I have the same problem here.
I have EMF model structured as follow
Model:
prop1:
.name
.value
prop2:
.name
.value
etc...
In the Bindings page, on the left panel I select target widget (text), in the righ panel I select EMF, Model, and property "value" of the object prop1; in the right panel, above the filter textfield I read what I suppose to be the correct form model.prop1.value for the binding source.
After confirmation, the binding is added to the table at the top (bound properties), but in the column "Model" I have model.value and not model.prop1.value as expected.
Of course the binding for me it isn't working. I get a null object from the model.
Is the same for you? Is this right behaviour?
Anyone out there that can confirm/correct/suggest ?
Thanks.
Stefano
FUDForum. Page generated in 0.05247 seconds
